Remote oil fiter on 5.4L Expy
Hello all you Bearers of Expedition knowledge. I have a 97 expy eddie Bauer with the 5.4L, it has the remote oil filter. Well, after searching the threads I see they all eventually leak so I need to fix my hoses which leak at the crimps. How about instead of replacing the hoses, just remove the whole remote filter and put the filter back on the engine block? I know I would need to replace the lower radiator hose, but what do I need to do to the engine block, a fitting of some sort? I am unsure, is this possible to do?
Thanks
Thanks
I have a 1998 4.6 windsor with 4wd. There is no way for the oil filter to go back on the engine block. The hump from the front axle makes it impossible. You may want to get under it if you have 4wd to see if the hump on the front axle is the reason the installed the oil filter at the front bumper.
mine are leaking bad as well, I checked with dealer they wanted $275 for it, I found one on ebay for 179.95 with free shipping. here is the link
eBay Motors: Ford Remote Oil Filter Hose Assembly, F8TZ 6716-AA (item 260329189731 end time Jan-07-09 08:18:44 PST)
John90
1997 - 2003 F150
01-15-2014 11:35 AM
mr69stng
1997-2006 Expedition & Navigator
01-13-2009 01:35 PM
