Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-08-2006, 03:52 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
Mo' Whistle
Ok, so i think i'm going to go ahead and upgrade my IC to one out of a 6.0L. I talked to Garrett at www.blackclouddieselperformance.com to get the kit to convert my early 99. I just read about removing the insulation on the hot side intercooler pipe to make more whistle and was wondering if this was somthing I could do when installing the 6.0L IC. If so that would be really cool.
Thanks
Adam
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #2 (permalink)
Old 05-08-2006, 05:27 PM
PSNut's Avatar
PSNut PSNut is offline
Garage is empty, add now
PSNut is gaining momentum as a positive member of FTE.
Quote:
Thanks
Adam
Yes...it's a good time to do it. Pull the wrap off with your hands then apply some chemical paint stripper and wait about 1/2 hour.Wire brush off the glue goo.Prime tubes then paint the color of your choice. I use high gloss black.Looks really nice.
Nut
__________________
Jim
'02 F250,4X4,7.3L PSD,DP Tuned,supporting mods,empty wallet.
  #3 (permalink)
Old 05-08-2006, 05:32 PM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Your early 99 has the foil wrap on the hot side pipe? I thought that started on 99.5+ models...
If so, it'll definitely make a noticeable difference once it's off.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
  #4 (permalink)
Old 05-08-2006, 05:55 PM
rickgmi's Avatar
rickgmi rickgmi is offline
rickgmi is starting off with a positive reputation.
just pulled mine off today...check out my pics, also tells how i did it...only took 1 1/3 hours
__________________
Early 99, F350, Ext Cab Xlt, Drw 2wheel, 7.3,Superchip, Bd monitor, Stainless Hpop Cross over, Sonnex/Tricumulator, Banks Big Head, Insulation off intercooler tube, muffler delete, CCV mod open air, 46637 air filter,
  #5 (permalink)
Old 05-08-2006, 06:38 PM
ryaneverk2's Avatar
Sounds like you did yours the same as I did mine, Rick.
http://community.webshots.com/photo/...86590301OtHfpL
__________________
Ryan Arthur
My Truck Pics
  #6 (permalink)
Old 05-08-2006, 06:40 PM
rickgmi's Avatar
Kewl...I might have gotten the Idea somewhere..I read Alot..lol
It worked out good...did you use the same tools and cleaners I did, Mine did come out really shinny...might just do the passenger side so they look alike
__________________
  #7 (permalink)
Old 05-08-2006, 07:22 PM
ryaneverk2's Avatar
Yep, same stuff: WD-40 and brake parts cleaner, just sprayed it on quite a bit a bunch of different times as I went. Used a wire wheel attachment on my drill, and some SOS pads, and some Simple Green at the end to sort of clean it up. Rinsed it all off with the hose real good. My hot side tube now matches the cold side (passenger side) nicely. I figure when I go to clean the whole engine with some Simple Green that any pipe discrepancies will even out some.
__________________
Ryan Arthur
My Truck Pics
  #8 (permalink)
Old 05-08-2006, 07:34 PM
BuickTurbo's Avatar
BuickTurbo BuickTurbo is offline
BuickTurbo is starting off with a positive reputation.
Quote:
That's quite a chemi-cocktail you got there. I used carb cleaner and a polishing stand with a wire wheel. Covered myself in glue boogers. I tried the blasting cabinet....lets just say the glue Ford uses needs to be applied in some military fashion cuz it didn't phaze it.
__________________
Dan
2005 CC DRW with a sunroof - who'd a thunk it?
1987 GN 528 hp...on the street
"IF YOU CAN'T HEAR IT....IT AINT RUNNIN'.
  #9 (permalink)
Old 05-08-2006, 07:41 PM
rickgmi's Avatar
now thats a shine
Mine came out really good, but i did work that brush real good over it, I like polishing stuff so maybe i have the touch...lol..the picture was taken with no Flash and the hood was blocking most of the sun from behind
__________________
  #10 (permalink)
ryaneverk2's Avatar
Quote:
Hahaha... good description. Using the wire wheel my arms and hands and the floor were covered with the same stuff.
I was also surprised at how tough that glue stuff was! Whoever put it on didn't did a hell of a job.... it sure didn't want to come off. Alas, in the end my will was too much for it, and along with the smell of victory came the sound of turbo whistle tasting freedom for the first time.
__________________
Ryan Arthur
My Truck Pics
  #11 (permalink)
Old 05-08-2006, 07:45 PM
rickgmi's Avatar
time
Hey Ryan how long did it take you, it might just be who worked that day putting the stuff on,,mine really was'nt that bad, around an hour and 20 minutes and I had it in and out,,but I did keep a spray of WD on it in the areas I worked...
__________________
  #12 (permalink)
Old 05-08-2006, 07:48 PM
PSNut's Avatar
Chemical paint stripper makes the job quick and easy. Just need good protective gloves.
Nut
__________________
Jim
  #13 (permalink)
Old 05-08-2006, 08:19 PM
BuickTurbo's Avatar
Nut,
I tried that stuff too. No workie.
__________________
Dan
  #14 (permalink)
Old 05-08-2006, 10:07 PM
C M Budke's Avatar
C M Budke C M Budke is offline
C M Budke is starting off with a positive reputation.
Quote:
My early 99 (8/98) doesn't have the wrap. But after seeing rickgmi's pic, I need to do some polishing. That looks awesome man! Guess I'll have to start wet sanding, then hit it with some tripoli and rouge. Sounds like another six-pack Sunday afternoon!
__________________
early '99 F-250 Lariat Extended Cab 4x4 7.3L Power Stroke - Bright Amber Metallic / Light Prairie Tan Metallic: 4" Exhaust, Kwik Filter, Wastegate Mod
  #15 (permalink)
Old 05-09-2006, 03:26 PM
ryaneverk2's Avatar
It really didn't take too long. Pulling off the foil using pliers took about 20-30 minutes. I should've scored the stuff first w/ a knife but I was stubborn. Grinding the glue stuff off took probably 45 minutes, stopping every few minutes to wet down the working area w/ my chemical concoctions. Cleaning it up at the end took another 15 or so, w/ the Simple Green, SOS pads, and garden hose.
__________________
Ryan Arthur
My Truck Pics
Tags
73, 99, blackclouddieselperformance, cold, early, f250, foil, ic, intercooler, make, mo, powerstroke, side, whistle, wrap, wraping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
