Vibration
05-08-2006, 02:12 PM
on
Vibration
Hi, I have a rumble when the truck is loaded with the camper. It vibrates only when I go foward from the start or when I climb steep hill at low MPH. It looks like the wheel are jumping?
Any idea?
05-08-2006, 09:59 PM
Anything broken underneath? Leaf spring, shock mount, carrier bearing? Could be any number of things.
05-09-2006, 12:21 AM
Supercab, regular cab we need all your truck info in a signature to be able to help you........
05-09-2006, 06:01 AM
on
when you load the truck, you are changing the driveline angles. you may have a u joint that needs replacement or the carrier bearing if you have an extended cab. there could also be a spline off one of the drive axles, but look into u joints first and see if there is any rust or discharge from them.
05-09-2006, 08:35 AM
on
My truck is a super cab, long box. It vibrates only when camper is on, 2300 pounds in the box. Other than that, no vibs, even a 90 MPH.
05-09-2006, 09:34 AM
on
also, you may be experiencing a miss in the engine or if you have auto trans, it might be the converter or trans with the extra weight on the truck. I would imagine the u joints would do it all the time.
05-15-2006, 05:07 PM
on
Found the problem. The mechanic cut off 2 inches from the drive shaft middle support and changed the bearing. No More vibs. I tried it in a 18 percent hill, dead stop and pedal to the floor, no vibs at all.
The drive shaft was to much out of alignement.
stlrfan1
1983 - 2012 Ranger & B-Series
06-20-2013 08:07 PM
pit_of_pity
17
03-24-2011 04:50 PM
jjmaas
06-14-2010 02:26 PM
Xwarrior86
01-11-2005 09:12 PM
