power windows wont work on all passenger doors.
hi i was wonderin if anyone has this problem. on all passenger doors they can not roll down their windows at all only from the drivers door. i made sure that the window locks wernt on and the problem still happens. could it be the switch and relay? also i have problems with the head lights too the dont automaticly come on anymore i have to manually turn them on. could this be cause i plugged in my stock trailer light wires? thanks
It is common on the 97-98 for the wires in the door jamb (large rubber connection ) to break, pull the lower boot back and check the wires by gently pulling on them, the broken ones will stretch. solder a piece of wire in between the broken ends and shrink wrap.
As for the Daylight running lights, there should be a module below the driver side headlight on the inside of the radiator support, the plug gets wet and corrodes, clean and you might fix the problem..
dadsgp
05-25-2015 06:44 PM
