Replacing kingpins... - Ford Truck Enthusiasts Forums
Old 05-23-2002, 11:46 AM
tonyss96dcm tonyss96dcm is offline
tonyss96dcm is starting off with a positive reputation.
How do I remove the sleevs of the kingpins, never done this before so I don't want mess it up, and how to insert the new ones? I know of using a hydralic jack and a socket that fits over the sleev, but is there another way, besides the machine shop at the corner?
Truck is completely taken apart, frame has been sandblasted and painted, now its time to do the suspension.
Thanks in advance.
1970 F100
00 Dodge Ram
96 Impala SS
63 Impala
Old 05-23-2002, 08:11 PM
jds1971 jds1971 is offline
jds1971 is starting off with a positive reputation.
Old 05-24-2002, 09:27 AM
William William is offline
William is gaining momentum as a positive member of FTE.
Take the I Beams with spindles attached along with a new set of king pins and I Beam rubber bushings down to the local machine shop. Have the old pressed out and the new installed.
William in Atlanta
Old 05-24-2002, 07:28 PM
Fordknut Fordknut is offline
Fordknut is starting off with a positive reputation.
Now, back in the fifties (I'm dating myself!) when most cars as well as trucks still used kingpins, we just went to "Monkey-Wards" and picked up a kingpin set which included new bushings and a combination reamer/driver. We drove out the old bushings, drove in the new ones with the perfectly sized driver and then reamed the bushings with the reamer. Worked perfectly every time. There must still be drivers and reamers available, albeit, they probably ain't cheap any more! This is not a "tuff" job and I'm sure you can find the tools and do it yourself. Whether or not the tools will cost more than having a shop do it I don't know. BTW, the bushing driver is a "step" design; the bulk of the driver fits inside of the bushing with just enuf lip to fit inside the spindle bore and catch the bushing. If you've got a barn full of "stuff" lying around like I do, you could probably find something to use for the driver. I guess you could (as you said) use a socket in a "pinch".
Old 05-28-2002, 08:39 PM
red68ranger red68ranger is offline
red68ranger is starting off with a positive reputation.
Take the I Beams with spindles attached along with a new set of king pins and I Beam poly bushings down to the local machine shop. Have the old pressed out and the new installed.
Tomorrow you'll still have your hair, your religeon, all the skin on your knuckles and you'll thank Wm in Atl and
Dan in Charleston
Old 05-28-2002, 10:30 PM
truckofdeath truckofdeath is offline
truckofdeath is starting off with a positive reputation.
Post Replacing kingpins...
I attempted the same repair last summer on my 72 f100, and I ended up losing my mind, friends, and about 2 weeks of my life. Take it to the shop.
mike
Old 05-29-2002, 04:08 PM
[updated:LAST EDITED ON 29-May-02 AT 04:09 PM (EST)]
Well, it seems like nobody likes to mess with this things, I'm gonna give it a try and hopefully it won't take me long to realize that I need to go to a shop. Thanks for the info guys.
1970 F100
00 Dodge Ram
96 Impala SS
63 Impala
Old 05-30-2002, 02:16 AM
gadams gadams is offline
gadams is starting off with a positive reputation.
yeah, man. if it takes more than five minutes to beat out the kingpin, GIVE UP!!! Don't be like me and try for several hours. Another tip: propane torches on these kingpins is like trying to move a dumptruck by blowing on it. Good luck!
Greg
67 F100 CCS 390 cruise-o
Old 01-14-2009, 04:23 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
i cant wait to get my kingpins done. i already have new shocks, new drag link and rag joint steering coupler and she feels like a whole new truck on the freeway. nice tight steering.
Old 01-14-2009, 06:00 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Quote:
I'm gonna give it a try...
Good for you! :)
The nay sayers aren't in AridZona, I guess. ;)
It was a snap to take apart and put back together, in my case.
Especially as they are saying, taking the whole dangged axle out. YMMV!
I said that for others because I know-ed this already...
"Truck is completely taken apart, frame has been sandblasted and painted,
now its time to do the suspension." -Tony
I didn't ream mine (no reamer, too dangged expensive at the time) I took
the knukles to the machine shop and instead of charging $10 labor each
side they only charged me $10 total because...
"the knuckles were so clean we didn't have to clean them first". :)
I cleaned them up nice and pretty because I wanted them to spend time
doing a good job on the reaming and not spend it cleaning the suckers.
That was $10 to drive out and insert new bearings and ream them to size.
I'd've rather done it myself and will look into the right sized reamer again
next time. BTW, my fancy hydraulic press looks like a bottle jack and the
underside of a double-wide trailer house. LOL :)
Alvin in AZ
Quote:
1970 F100
{snipped "bad words";}
Old 01-14-2009, 06:20 PM
wickedinhere's Avatar
wickedinhere wickedinhere is offline
wickedinhere is starting off with a positive reputation.
I just changed a set on my 68 they came out pretty easy but i did heat them with a torch
and it took some beating with a 3lb hammer. If i hadnt used heat it would have been real tuff job.
Old 01-14-2009, 10:20 PM
it has been rumoured that henry ford used to browse different junkyards to find out which component lasted the longest, and it was the kingpins, so they decided to go cheap after that and save the company money.
http://www.snopes.com/business/genius/fordpart.asp
Old 01-15-2009, 01:30 AM
snopes.com: Henry Ford Junkyard Parts
Cool post. :)
My father-in-law knew just about everybody because he talked to everybody.
One day he talked to a guy collecting Ford door locks at a wrecking yard and
the story is that he was trying to figure out a way to cheapen the manufacturing
of the product by one dollar. That's was big bucks to Ford Motor Company,
and would share some of that saved money with him for his ideas. ;) His goal
was to improve them more than anything else tho, he was very specific
about that, it was like a game to do both real good.
Alvin in AZ
Old 01-15-2009, 01:40 AM
rsdjcarter's Avatar
rsdjcarter rsdjcarter is offline
rsdjcarter is starting off with a positive reputation.
So I wonder if having them upside down on the trucks was his idea?
Fastest you've been in a car (or truck)? dorkpunch General Automotive Discussion 208 05-19-2016 08:59 AM
Help with 60 F100 kingpins cordespc 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-07-2007 09:24 AM
kingpins tankbuster71ford 1967 - 1972 F-100 & Larger F-Series Trucks 8 09-04-2004 05:24 AM
How to figure out the gear ratio... tonyss96dcm 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-11-2002 06:48 PM
kingpin bushing reamer cccc1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 04-20-2000 08:22 AM
Tags
1960, 1973, 67, bushings, f100, f250, ford, king, kingpin, kingpins, pins, replace, replacement, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
