Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-07-2006, 11:34 PM
jtharvey's Avatar
jtharvey jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
6.0 Intercooler Install Writeup
I installed the 6.0 IC about a month ago, but I realized I've didn't give a very thorough writeup of how to do it. So, hopefully, this will help.
No real tricks to it. It's pretty straightforward. I used the intercooler connection tubes and hoses from BCPD, which allowed me to not have to use any adaptors. However, you can use the stock tubes, but some modification will be necessary. Here's a thread that should help with that, go to post #11.
http://www.ford-trucks.com/forums/sh...d.php?t=466349
You don't have to pull the radiator at all. Just remove the top radiator support. First you have to take off the black rubber piece that's between the grille and the radiator support. You might want to get some new plastic body pins that hold it on because you will most likely destroy the old ones when you pull them out.
Take out the 2 radiator support bolts, on the back side of the radiator support beam, near the top of the radiator. Then remove the bolts that hold the radiator support beam. I think there's 4 per side, 2 in front, 2 in back. Then lift the radiator support beam out. It's snug, and you may have to do some prying to get it out.
Once it's out, you should be able to see the intercooler that's directly under it. Remove the clamps and hoses connecting it, if you haven't done so already. Once they're free, the intercooler should just lift right out. The fit between the intercooler outlet and some of the A/C lines & radiator may be tight. I had to loosen the overflow bottle to allow the A/C lines enough room to move so I could get it out.
Installation of the new one is reverse of removal. The 6.0 IC is a tight fit, but it'll go. Getting the radiator support beam back in place was probably the toughest part of the whole thing. But, with some prying and a rubber dead blow hammer, it finally popped back into place. Put all the little pieces back together, fire up the engine to test for any big leaks, and take it for a test drive.
Hope this helps. Let me know if there are any questions.
__________________
Jeremy
See My Webshots for pics.
  #2 (permalink)
Old 05-08-2006, 07:14 PM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Good writeup, JT. Saved for future reference.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
  #3 (permalink)
Old 05-08-2006, 07:48 PM
Lushman's Avatar
Lushman Lushman is offline
Lushman is starting off with a positive reputation.
Thanks JT, I am also saving it for future reference like Ryan. How much did it lower your EGT's? I think your initial impression was around 100*?
__________________
2000 F350 4x4 Lariat CC
4" MBRP SS exhaust, AFE Stage 2, WW, SS HPX, CCV MOD, Mag-Hytec, Amsoil dual bypass oil filter, 203/Billet Thermostat, Zoodad, Coolant Filter, Powerslot/Hawks, Hutch&Harpoon mod, Dahl 100, MAP regulator, BTS VB, TruCool, AIH delete, 3 guages, 4 pos DP Tuner,
  #4 (permalink)
Old 05-08-2006, 08:33 PM
jtharvey's Avatar
Quote:
Yeah, but it helped most while towing and at WOT. Daily driving and driving unloaded/empty, there's not much of a benefit. But, it's when you really start to push more air through the IC that it helps.
__________________
Jeremy
  #5 (permalink)
Old 05-08-2006, 08:41 PM
Ford Truck Racer Ford Truck Racer is offline
Ford Truck Racer is starting off with a positive reputation.
appreciate the writeup, hope to get my intercooler in about a week and start the install.
__________________
99 F-250 PSD auto 4x4
dp-tuner, ftvb, 6637, 4inch dynomax exhaust, hpx
  #6 (permalink)
Old 05-08-2006, 10:10 PM
arninetyes arninetyes is offline
arninetyes is starting off with a positive reputation.
Thanks for the write-up! Looks like it will be as easy as I'd hoped.
Uh, oh. Let me backtrack - as SIMPLE as I'd hoped. Often things that should be simple and easy take a long, long time.
__________________
'00 F250 4x4 StdC LB 7.3L auto
some mods, but never enough
  #7 (permalink)
Old 05-08-2006, 10:36 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud of
Quote:
Oh...how I wish that wasn't true.
__________________
Scott - FTE moderator
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 98 Navigator, 5.4, AT, 4x4. Almost completely stock...almost
  #8 (permalink)
Old 05-08-2006, 10:41 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
AMEN.
BTW, nice writeup JT. You really need access to a local dyno to measure your results as you go. I bet that BTS transmission will be worth quite a bit for you when you get it.
__________________
Mike
2001 Auto Crew Cab 4X4. 38R and Swamps Hybrids. Transgo and diode Tranny. 400HP but not really. 05 front end and stickers makes it faster.
  #9 (permalink)
Old 05-08-2006, 10:53 PM
jtharvey's Avatar
Quote:
Originally Posted by Tenn01PSD350
AMEN.
Thank you. I know there's a local chassis dyno around here, but I don't know if it's big enough to fit a diesel on. And, I have no idea how much they want to charge for a few dyno runs. But, I'd be curious to know how some of them are affecting HP numbers. I'd especially like to know how big of a difference it makes when I do the bigger fuel supply lines and additional fuel pump.
I'd sure like to put the truck back on the BTS dyno before I leave, once the trans is in. But, I know it's going to be a long day anyway, and since the trans is being done for free, I don't want to ask for more. But, we'll just to see how it goes I guess. I did get the torque converter in last Friday though. That thing is a beast, weighing in at 65 pounds. And, my girlfriend is thrilled that I'll have a purple part on my truck.
__________________
Jeremy
  #10 (permalink)
Old 02-16-2008, 02:53 AM
QwkTrip QwkTrip is offline
QwkTrip is gaining momentum as a positive member of FTE.
Digging up an old thread here, but I'm wondering what is the performance difference between 6.0L intercooler and Banks for 7.3L?
  #11 (permalink)
Old 02-16-2008, 08:33 AM
alan hodges alan hodges is offline
alan hodges is starting off with a positive reputation.
Jeremy, Who is BCPD? I'm thinking I know them but can't place it. Thanks Alan
__________________
99 F350, cc, lb, 4" lift, ats housing,ats4"ext,DP6 tunner,k&n cold air,6.0 tranny cooler, 6.0 inter cooler ats deep pan,fuel reg kit,auto meter3 gauge piller,itp fuel filter kit,s.s.hpx,billet billet converter, transgo tugger kit.
99 ranger 4x4 quad cab
  #12 (permalink)
Old 02-16-2008, 09:34 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud ofPaysonPSD has much to be proud of
Quote:
This is an old thread so I will answer: BCPD is http://www.blackclouddiesel.com/
  #13 (permalink)
Old 02-16-2008, 01:03 PM
cookie88's Avatar
Quote:
The 6.0 cooler is a little bigger. It should flow a little more and it should perform a little better.....but the reality is the performance difference is minimal at best.
__________________
  #14 (permalink)
Old 02-16-2008, 01:09 PM
Thanks, cookie! Sounds like it comes down to cost.Appreciate the info because I've been thinking about an upgrade recently. I'm glad I found this thread.
  #15 (permalink)
Old 02-17-2008, 12:05 AM
jtharvey's Avatar
Quote:
Actually, it was a different company, Black Cloud Diesel Performance, not to be confused with Black Cloud Diesel. However, there was confusion around the name, so BCDP's name was changed to Pure Diesel Power. Garrett Shields runs the company and is a great guy to deal with. Here's his link: http://www.puredieselpower.com/
__________________
Jeremy
Tags
2007, 60, 60l, 6o, 73, 73l, ford, install, intercooler, kit, removal, sale, swap, upgrade, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
