Y-pipe doesn't quite fit the shorty headers
Finished my rebuild and the engine runs but has a massive exhaust leak on one side. I had the feeling this would happen when I reattached the y-pipe to the shorty headers (Summit brand). Not matter what I did I just couldn't get everything to line up perfectly.
- Current setup is metal to metal. I don't remember any graphite (or other) seals on the old manifolds (which of course I threw away!). Is there supposed to be a seal and if so where do I get one? I can't find any reference to a seal at any of the internet supplier sites.
- I'm thinking the easiest solution would be to cut the y-pipe and use one of the flex exhaust connectors. Any reason why this would be a bad idea?
My bassani y-pipe missed my Ford headers. They were in the ballpark but not enough to bolt on and go.
I took a good look at where the pipe needed to be and how it needed to be moved...heated it up with a torch and bent it by putting a stick in the pipe with my foot on it. Fits now w/ no leaks.
Bought a set of Ford Racing Shorties and original Y fit perfectly. No donut, metal to metal. Now looking to dump original exhaust and go to duals. Heard it both ways that crossover (X or H) is necessary or not necessary. What's the real skinny? Got a bung in the collector of the right header for the O2, so that won't be a problem. Looking for another mpg or two.
Lagniappe
11-01-2016 09:42 PM
Red454sedgwick
28
12-24-2015 02:02 AM
Dayzed50
1978 - 1996 Big Bronco
11-02-2010 10:04 AM
