LED Skull hitch cover used as a Third Brake Light.... - Ford Truck Enthusiasts Forums
Old 05-06-2006, 06:19 PM
Greywolf's Avatar
Greywolf Greywolf is offline
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
We made a custom bracket out of thick aluminum stock, following the contours of the skull. It was painted black to hide the bracket. Very cool - it looks like the chrome skull is floating in the back window.
But wiring it was interesting. We found that only one connection actually did anything as far as lighting up the eyes. The rest of the wires from the flat connector did zero (except the ground wire).
This was NOT cool, because we wanted to multi-task it. Running lights, brake lights, possibly turn signals as well.
What we found is that a 3K ohm resistor was needed to connect the running lights, and that each wire had to have a DIODE installed in it.
A diode is an electronic device that only allows voltage to run in ONE DIRECTION. This was needed to keep the turn signals from becoming HAZARD flashers, and also to prevent the running lights from over-riding the turn signal flasher.
Three wires are needed.
The running light wire has 3K of resistance in it, and a Diode.
The left and right turn/brake wires have a diode.
We nabbed the diodes at radio shack - 3 amp 200 volt rated just to be sure. ($1.29 a pair)
The striped end of the diode should be installed on the side towards the skull. Think of it as the negative side.
We used jumpers to try different resistors until we found a set that made the eyes of the skull light dimly when the running lights were on, and became bright when either the brakes or turn signals were used.
The next project calls for using a pair of these on a 1950 Chevy truck as tail lights, so that application will be slightly different.
Again - although the hitch cover has a flat trailer connector on it, only the white (ground) wire and the brown (running lights) wire is connected to anything.
All of the above was installed in a 1950 FORD 2 door. One wire runs from the running lights, with a resistor and a diode. One wire each with a diode in line with it runs from each rear turn signal/brake wire.
The install went smoother than cookies and cream...
Pictures later, it's miller time!!!
Old 05-06-2006, 08:24 PM
cangim's Avatar
cangim cangim is online now
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
Sounds pretty sweet, looking forward to some pics! Do you have it setup to flash or just steady on?
Old 05-06-2006, 08:33 PM
Greywolf's Avatar
States of activety:
(Lights off)
TS on: Skull eyes flash
Brakes on: Skull eye lights bright
Brakes + TS on: Skull eye lights bright
(Lights on)
No input: Dim eye lights
T/S: Skull eyes lit dim, but eyes flash bright
Brakes: Eyes go bright
T/S + Brakes: Eyes lit bright
This is the reason we put a resistor in line with the marker lights - we wanted a difference between signals and just plain lights.
The resistor makes the marker lights dimmer than a brake or turn signal light.
The problem here was that the same connection was supplying power from the turn, brake, and marker lights. We had to reduce the current from the marker lights using resistors. This brought the voltage down, so it reduced the power.
Putting it simply - one of the inputs had to be reduced (the markers). So we limited it. The others are straight 12 volts.
If we did not limit the juice from the markers, they would be the same intensity.
- I hope that makes sence to you
Old 05-06-2006, 09:10 PM
cangim's Avatar
Yeah all makes sense to me (electrical engineer), Was just wondering if you added a timer or a flasher circuit like a 555 timer to make the leds flash rapidly, several times a second. But I do like the idea of lowering the intensity with the running lights.
Old 05-07-2006, 10:29 AM
Greywolf's Avatar
Quote:
We kept it very basic. There's no need to modify the flash rate in this application.
If I did want to do that, I'd setup the timer circuit to replace the T/S flasher unit itself. But this way everything is easily replaceable, flasher goes out - head to any parts store. The wiring and components are purposely heavier duty than needed so they will last.
Old 05-07-2006, 11:39 AM
Greywolf's Avatar
Pictures of the project showing the bracket that we made
Old 05-07-2006, 12:15 PM
cangim's Avatar
I like it! that is definately trick, it does look like it is floating from the back.
Old 05-07-2006, 03:57 PM
Greywolf's Avatar
Cautions when working with Aluminum plate:
Avoid grinding aluminum on a bench grinder - it's a soft metal and can cause the stone to explode.
A saws-all can remove most of the metal at odd angles if you make several cuts from different angles. Sort of like making chisel cuts.
Once you make a bend (unless you "aneal" the metal first, which softens it) consider it BENT. Aluminum will crack if worked too much. Don't go back and forth...
YES, aluminum does conduct electricity. But run a ground anyway - dissimilar metals can lead to corrosion and mess up continuity.
Wire wheels are the BOMB for smoothing cut edges... You can carve soft aluminum with a wire wheel, so be careful how much you take off.
~Wolf
PS: I'll drop two more pic's here showing it lit up later on.
PPS: In the '50 Ford, the brake lights are on the same wire as the turn signals.
diode needed in TC lockup mod?? carl2591 1999 - 2003 7.3L Power Stroke Diesel 7 02-27-2017 08:59 AM
1978 F600 light wiring woes Pinzer Large Truck 8 02-12-2016 10:38 PM
4 pin trailer connection SEAL1 Explorer, Sport Trac, Mountaineer & Aviator 6 07-13-2015 05:30 PM
4 pin trailer connecter SEAL1 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 11 06-24-2015 09:59 AM
2001 Expy.no trailer-tow power to running lights BaitGuru 1997-2006 Expedition & Navigator 7 05-12-2010 11:14 AM
Tags
brake, county, cover, covers, eyes, flash, head, hitch, light, lightup, signals, skull, trucks, turn, turning, utah
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
