wiring diagram for alt/reg
I have a 56 panel truck with a 460 engine. I have the ford alternator with the external regulator. Does anyone have any pics or diagrams on how to wire it? I need to know how to hook up battery to alternator to regulator and where does the starter solonoid figure in?
Thanks to all,
James
Thanks to all,
James
Here's a diagram without the shunt and factory ammeter. Just to make sure you know the ammeter and shunt is optional, and a aftermarket voltmeter is a better choice. The choke wire is optional too. You can leave the "S" terminal on the alternator empty if you do not have a factory electric choke on the carb.
...Is the (I) connector on the regulator NOT used at all? I have a Holley Avenger carb. w/electric choke. So let me see:
The Alternator connects:B gets power from the battery side of the Solonoid.
F(field) gets connects to the F on the regulator.
S(stator?) gets connected to the electric carb choke.
The Regulator connects: I is NOT used.
A connects to the battery side of the solonoid.
S connects to the run on the ignition switch.
F connects to the F(field) on the alternator.
polarisman729
25
06-24-2011 09:56 AM
steve benson
04-17-2006 09:57 PM
jambroson
01-28-2004 10:38 PM
