Fuel Filler Adapter?
I've searched for the last hour trying to find a post concerning a nozzle adapter for filling the truck up with diesel from a class 8 nozzle (in other words, getting fuel from that big nozzle into our little tank opening). I thought I read someone found adapters for sale somewhere in the past six months (they slip over the large diamter nozzle?)...Is this even the way (using an adapter) to go or should the fuel filler neck be modified to accept the larger diameter nozzle? Any help/advice would be most appreciated!
Originally Posted by guzzle92
There was a thread about this a while ago and the general concensus was to pull the filler neck, use a hole saw the diameter of the opening and simply cut out the restrictor. Clean metal shavings from the neck and re-install. The ones that did this said it works great.
Badmrscary
05-22-2016 05:04 PM
vacuumbed
07-25-2011 06:21 AM
