Door Ajar light etc.
I sometimes get a situation where the instrument panel says the door is ajar when it is not and the dome light does not want to go out. Usually it will go out after a minute or so. There has been a time or two where I couldn't get it to go off without opening and closing the driver's door a few times. Anyone have any good ideas as to what I should check? I assume the switch is part of the door handle. Any odds on whether it is the switch or some other part?
Randy
1998 F150 XLT 4X4 4.2 5speed blue
Randy
OK so exactly what is it that I am supposed to spray with WD40? The lock cylinder in the door handle? or the ignition lock cylinder? or the door latch mechanism? Where is the switch that works the dome light etc? I assume it is part of the door opening mechanism as there is no switch on the door jamb like in the old days.
Randy
Randy
