Stiff Gas pedal - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Stiff Gas pedal
Old 05-04-2006, 03:59 PM
Canadianice Canadianice is offline
Canadianice is starting off with a positive reputation.
Stiff Gas pedal
I have an 84 BII and everytime I turn mt truck on my gas pedal goes from nice and progressive while off to friggin stiff when on. It been slowly getting worse over the past month. There is no binding since I have checked all the linkage to the carb several times. Also the pedal moves beautifully when the truck is off, so i know there are no snags. If anyone could enlighten me please do so because this heavy gas pedal is naggin at me.
Brake pedal giving me grief rbrungard2012 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 01-06-2015 06:49 PM
Issue after putting carb back on apbtpetey 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-25-2013 09:57 AM
gas pedal resistance Nally427 1987 - 1996 F150 & Larger F-Series Trucks 4 09-13-2012 07:39 PM
Stiff clutch pedal bashby 1987 - 1996 F150 & Larger F-Series Trucks 5 02-14-2012 02:34 PM
Adjusting throttle cable/gas pedal pressure 73Galaxie 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 05-23-2003 12:11 AM
Tags
2005, accelerator, aod, bronco, cable, diesel, f150, ford, gas, hard, ii, pedal, stiff, throttle, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
