Ahh guilty too, i wouldn't be doing both diff fluid changes either if it wasn't for this thread popping up and making me think... Thankyou GUZZLE!! this site is just great
__________________
WILL PAA #30
2001 F250 Auto EC LB 4x4 THE DP Tuner, Lots of other goodies
Jim and Rick, seriously, where are we going?
Well its Sunday and after riding 54 miles(rear fluid nice and warm) on the way home changed it out. Did everything Guzzle said,let the permatex cure with the pan for a while then added fluid. Only thing, cleaned out all old fluid but only took 3 quarts until it started seeping out the weep hole. Do i possibly need to run the truck and add the rest?
__________________
Mike 2003 f-250 XLT CC 7.3 SB, auto, 4x4 373,s S-B air intake w snorkel,DP Tuner-NS,Stock,60T,80E,120R,140A, WW, CCV mod, SC Codereader, Isspros 3 pillar, foil del, MBRP 4 in duals, 285 Yoko,s A-T, Bilsteins, 2in shackle kit (Thanks Zack7.3), Zdad, CrimeStopper Alarm w remote start, Cobra 29 cb dual firesticks. PAA MEMBER 26#
Well, like i stated above, changed out the rear fluid and been running it (RP) for a week now and didn't have to add any friction modifier. No gripping or grabbing around corners. Real smooth. So far i,m happy with the RP. Hope this helps. Next, the front axle....
__________________
August 8, 9, 10. Me and Jim are staying at the same campground( Western Village campground). I,m staying the 8,9. The 10th is optional because of a family members birthday... Hope you and alot of others can make it... Megawatt(Jim) will be there.
__________________
