was wondering if anyone on here had one of these for sale or much experience with them... im leaning toward the 1.0 but i havent been able to find much comprehensive info on the .84 other than they put em in the 6.0??? I dont know, i could be totally wrong but thats why im askin here!
1.15, i think your right. I guess im more concerned with economy than driving a race truck! I used to drive a 12v cummins and it just seems like with this 7.3 there is very little boost until you get to 2100 rpm or so, where my 12v would spool from like 1200... so is it just a quicker spool up or would it spool at any lower rpm? I may very well stick to the 1.15 im just curious about the technical details. OK, so heres another think... If I upgrade injectors, hpop etc would the extra fueling lead to more boost at lower rpms?
You'll definitely loose fuel mileage if you get to a smaller housing.
I run the 1.0 housing. No you won't lose mileage. With normal highway driving at 75 mph I gained a solid 1 mpg sometimes 2. If you stay with stock injectors the ever so slight rise in egt's will be insignificant. No you won't lose top end boost, I get 28 lbs on stock injectors. My boost starts at about 1500 rpm's instead of the 2000 rpm's with the 1.15 housing. There are a few guys running stage one's with the 1.0 housing and with good tunes keep the egt's in check.
1dieselman, did you notice any increase around town? also how ever so slight a rise in egt did you notice? that is a sweet looking rig by the way. Im workin on a 97 f350 cclb i just bought a few months ago...
Yes I did but keeping in mind that it is a very small town but any direction that you come into town is a fairly decent climb. I noticed an increase of 50*. Thank you. My plans are installing a Intercooler, superduty 17* Hpop, stage 1.5 rosewood injectors, and tunes by DP. and keeping the 1.0 housing
