4.2L, interchangability
I'm sure this has been answered before, but I used up my # of allowed search attempts before finding the answer.
I have a '97 F150 4x2, 4.2L V6, with 110K+ miles. I had the engine rebuit ~2.5 years ago after the intake gasket went. Last week, after <20k miles the head gasket went (only 1 year warranty). I was planning on keeping my truck for another 6-12 months when this happened. In a few months I'll retire from my career as a professional student and start a new (much better paying) one with the naval research lab. I was hoping my truck would hold out for a little while longer, but then again, what interesting would life be without a few complications.
I'm weighing the options of getting a new headgasket or a used engine. I know that '97 and '98 year engines directly interchange, but they are pricey and hard to come by here in Maine.
So my question are:
Can I swap in an engine from '99-'03 years?
What will I need to strip from the old engine?
If this has been answered before, what is the link to the post?
Thanks in advance for any help.
TK
So my question are:
TK
I wish I could tell you for certain, but I don't know the answer. I do believe the newer engines will fit and work just fine in your truck, but don't know exactly what all must be transfered.
I can imagine there would probably be one or two things just different enough to cause headaches, but some of that is to be expected I guess.
Did the recent gasket failure cause engine damage?
If not, I would have the problem repaired again. The redesigned gasekts, or Felpro gaskets, are better than the stock gaskets and should last you a good long time. That is assuming there is no damage/warping involving the block, intake and/or head mouting surfaces.
Let us know what you do and how it turns out.
Thanks!
Thanks!
