Disabling PATS - Ford Truck Enthusiasts Forums
Disabling PATS
Old 05-03-2006, 04:43 PM
mgraveman mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
Disabling PATS
I am getting ready to put a modular from a 1997 E350 into an 82 F350, and am wondering how to disable PATS so that it can run in an older truck.
Any ideas?
Old 05-04-2006, 02:01 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
Any ideas?
Go to the dealer and see if there's a calibration code without PATS?
And then get a computer with that code from a junkyard?
Does the PATS system just use a resistor in the key like the GM's around that time? If so, you can get a resistor of the right value and wire it in and get around it.
Old 05-05-2006, 09:56 AM
Krewat's Avatar
I just did some research, and it looks like the Ford PATS system is a transponder-based system. Not easy to bypass.
Look at remote-start systems, they do sell PATS bypass modules that are basically programmed with the transponder code (2 keys required) and then there is a wire loop that transmits the transponder code to the computer. Nice hack.
However, there HAS to be a 5.4/4.6 computer that doesn't include PATS that you can use... again, ask the dealer's parts dept.
Good luck! And let us know how it works out and what you did to bypass it.
Old 05-05-2006, 11:04 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
use a computer from any SD truck those don't have PATS.
Old 05-05-2006, 11:13 AM
Oh, rezally?!?!
Will my van engine work fine with the SD engine and transmission?
Now that I think about it, the keys in those vans are the small one, like my 94 has. It is not like the newer ford keys that are large. Does that mean that this does not have PATS at all?
Old 05-07-2006, 12:05 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Vans don't have PATS. You will be fine
Old 05-14-2006, 10:41 PM
Thank you. I checked this with the ford dealer, and you are very correct.
Old 05-17-2006, 07:55 PM
Yeah I kinda have an inside scoop considering I am a technician at a Ford dealer.
Old 06-12-2006, 08:53 AM
02 LariatFX4 02 LariatFX4 is offline
02 LariatFX4 is starting off with a positive reputation.
Can't you also get a spare key and have it set to full time disable it?..I went to a car audio place and they said to get an alarm/remote start they had to put a spare key in somewhere to disable the system...(may be cheaper route than to get another computer....
Disabling PATS? exbxtoy Excursion - King of SUVs 6 08-27-2016 12:06 PM
Disable P.a.t.s. Phred P 1997 - 2003 F150 3 09-18-2014 02:38 PM
HELP PATS system still disableing the Truck Fully_Loaded 1999 - 2003 7.3L Power Stroke Diesel 6 12-04-2009 01:06 PM
Pats system fuse BURNSTOUGHFORD 1987 - 1996 F150 & Larger F-Series Trucks 0 12-01-2009 02:47 PM
can you disable the PATS on 97 xlt? 97expy Expedition & Navigator 12 12-21-2006 04:53 PM
Tags
99, bypass, bypassing, disable, disabling, f150, ford, fords, hoh, pats, road, sct, system, wiring, x3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
