Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-03-2006, 10:08 AM
sneak's Avatar
sneak sneak is offline
2002 Ford F-350
sneak is starting off with a positive reputation.
Stupid question.
I'm looking at putting together a processor with a reaction tank of say, 100-200 gallons, and two wash tanks. I feel stupid for asking this question with the research I've done, but I overheard someone ask if ethanol could be used instead of methanol... The main reason I ask this is because with another simple project(a still) I could make alcohol with roughly 85% ethyl alcohol, and 10% methyl alcohol.
__________________
Paul - OFF of the farm, now on a ranch.
2002 F-350 Powerstroke - AFE "Big Boost" BHAF filter element, Stancor GPR, DB Electrical 4KV starter
76 F-250 CamperSpecial - Hoping for a DT360 and a Spicer 6+1 trans
  #2 (permalink)
Old 05-03-2006, 11:27 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
Garage is empty, add now
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
This should be moved to the gas section. You'll get help there. You are in the diesel section at the present time. ( at least the ethinol question)
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #3 (permalink)
Old 05-03-2006, 11:42 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Are you talking about making Bio Diesel?
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #4 (permalink)
Old 05-03-2006, 08:15 PM
sneak's Avatar
2002 Ford F-350
Yes, sorry, I got ahead of my self.
__________________
  #5 (permalink)
Old 05-03-2006, 08:21 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
If you make Ethanol you will be getting a visit from ATF. The feds Require a permit to make more than 400 gal PER YEAR or they come and take you away!
The short answer to your question is yes, but not at home. Ethanol cannot be "distilled" past 98 percent. The remaining 2 percent is water...............and is enough to KILL the reaction. Ethanol can be made to 100 percent but it takes specialized equipment that is beyond most home-brewers.
In most cases Methanol is less costly than Ethanol and produces a better quality product with less chance of forming soaps.
There are no stupid questions.......................but I've heard some stupid answers
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #6 (permalink)
Old 05-03-2006, 08:29 PM
sneak's Avatar
2002 Ford F-350
FABMANDELUX.
I know it takes alot more time to get it past 96% in one still cycle, and that there will be much more waste past that point, but you can buy reusable desicant to "dry" your alcohol fuel, and they will also poison it to make it not fit to drink.
Also I know about the ATF, I live on a farm and it is much easier to recieve a permit, along with fewer taxes because of use with off-road vehicles.
I was unsure if it could be done, that's why I was asking. Is there a web page, or a couple of paragraphs somewhere that explains the pro's, con's, and prosseses to use it?
__________________
  #7 (permalink)
Old 05-03-2006, 08:47 PM
1935 Ford pickup
The amounts are the same for Ethanol or Methanol, all you are doing is swapping one alcohol for another. Even triple distilled Alcohol will be less than 98 percent, then it has to perculate through a "molecular-sieve" to remove the remaining water. After it is refined to 100 percent, ANY EXPOSURE TO THE ATMOSPHERE WILL CAUSE IT TO DRAW MOISTURE. Just not worth it. And I am a farmer also.
FABMANDELUX.
__________________
  #8 (permalink)
Old 05-04-2006, 12:24 AM
sneak's Avatar
2002 Ford F-350
That's the kind of definative answer I was looking for. Click the image to open in full size. Thank you fabman.
__________________
  #9 (permalink)
Old 05-04-2006, 04:48 PM
I was told by our local ethanol plant they have to mix 2% gas into the batch to make it denatured (not drinkable). This was to get past the ATF guys so wouldn't tax it as drinkable.
__________________
B5 soydiesel user
Sirius radio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
