Trans fluid ?
Trans fluid ?
Hey guys I am thinking about replacing the fluid in my truck. I have a 97 F150 4.6 w/ the 4R70W trannsmission. I have read that you can use Mercon V in place of the Mercon on the older ones like mine. I am just a little leary of doing this since my truck has 183000mi and don't want to ruin the tranny. Will the Mercon V do any damage if it is all replaced?
Ford released a chart on which fluid you should use, and it clearly indicates that a 97 4R70W should use Mercon.
Many companies trans fluid is compliant to more than one standard. Many I saw when changing mine claimed to be Dex III/Merc and Merc V. Those I would say are safe to use. If its only claims to be one, I would definitly make sure that it is Merc and not Merc V.
