Virginia Chapter Join Chapter, Leader:
Who does good kinping work in HR?
Old 03-12-2006, 12:29 PM
65vamonster's Avatar
65vamonster
65vamonster is offline
Well I am moving on the 65 to get it road worthy. I was wondering if anyone in Hampton Roads has had good luck with any shops replacing kingpins. I am removing the old and buying new, but apparently you need a kinping reamer to make the new pins fit the joint correctly. Any info would be greatly appreciated.
Old 03-13-2006, 12:21 PM
Franken-Truck's Avatar
Franken-Truck
Franken-Truck is offline
No info on local shops, but I'll ask my dad if he still has his reamer from his old '74 E-100
Old 03-14-2006, 09:55 AM
Rocket Racing's Avatar
Rocket Racing
Rocket Racing is offline
Call Berts Alignment in Virginia beach & see if he can help. Also, maybe Gregory's Fleet Supply in Va Beach on Cleveland Street, ask for the machine shop. Let me know what you find.
Old 03-14-2006, 06:55 PM
65vamonster
OK I beat on one of those kinpins today, heated it up, and beat on it some more. I didn't move it at all. I might have to check out one of those hydralic presses at harbor freight.
Old 03-14-2006, 07:01 PM
Franken-Truck
That stinks. . .just out of curiosity, I wonder how hard it would be to retro fit an 80+ ball joint front end into your truck? I mean the radius arms and beams are close to the same length. . .
Just thinking out loud, don't wanna mess you up
Old 03-15-2006, 10:16 AM
GLR's Avatar
GLR
GLR is offline
Just checking, did you take the retaining bolt out??? It has been left in before. I know some of the kps get really frozen. I have been checking around for a reamer, the best are an adjustable one so the fit can be "fine tuned". Very pricey..got spoiled going a mile down the road to borrow my neighbors' set.
Old 03-16-2006, 11:42 AM
Franken-Truck
So far it seems to be "no-go" on the reamer
Old 03-18-2006, 06:53 PM
65vamonster
Well no luck so far. Hopefully I will pick up a press some time this week to help out the situation. I did get the retaining pin out, although it did kick my butt at first.
Old 03-18-2006, 07:24 PM
Franken-Truck
Well, if you need any help, give me a holler
Old 04-27-2006, 03:27 PM
65vamonster
Just have to say thank you for recommending bert's alignment. Had me in and out in less than an hour. Incredibly nice guy, I will be going back there for the final alignment. If I weren't stuck at work all night I would get some pictures posted for everyone to see.
Old 04-27-2006, 08:37 PM
Rocket Racing
No problem glad he was able to help you out !
Old 05-05-2006, 02:34 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
For what it's worth, I have a king pin press and reamer that works on the 100-150 king pins (.875"). The press will do bigger ones, I did Sonny's Towing's GMC 3500HD with it.
SN65
06-08-2016 10:26 AM
Cowboy65
1999 to 2016 Super Duty
07-13-2015 08:08 AM
hipdqwik1
11-16-2013 01:14 PM
4griffins
06-23-2011 12:34 AM
jbomb
01-11-2006 05:45 AM
Quick Reply: Who does good kinping work in HR?
