Bio-D and SVO in same tank? - Ford Truck Enthusiasts Forums
Old 05-02-2006, 10:31 AM
bio-d bio-d is offline
bio-d is starting off with a positive reputation.
Question Bio-D and SVO in same tank?
Can I run bio-d and svo in the same tank. I've read some posts that say they don't mix well, but will this be a problem? I'll be running bio-d in cold weather and the bio-d would benefit from warming anyway.Mike
Old 05-02-2006, 12:16 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Not a good idea they dont mix at all. You dont have to warm BD to keep it from crystalizing just mix it with some good ole #2
Old 05-02-2006, 07:13 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
What he said
Old 05-02-2006, 11:41 PM
Thanks for the replies. What exactly is the problem with bio and svo not mixing, as long as I'm using the svo heaters? Do they react to form another compound?
I'd rather not have to use any #2 if I don't have to. I have two tanks on my 87 6.9 idi, so one would always have bio or #2, but on a long trip I'd like to use svo when available. Mike
Old 05-03-2006, 12:56 AM
Phydeaux88's Avatar
The specific gravities of the two liquids are to far apart.
WVO is a much larger heavier molecule than BD (that's why the specific gravities are different)
Old 05-03-2006, 01:20 AM
tobetaxfree tobetaxfree is offline
tobetaxfree is starting off with a positive reputation.
SVO not WVO?
I believe he wrote Bio-D and SVO. SVO is different than WVO. I understand SVO is refined vegetable oil like you cook with. Waste vegetable oil is the stuff that restaurants use in their deep fryers. I also believe that this stuff is often a liquid shortening meaning it is partially hydrogenated. If he meant WVO great. If he actually meant SVO, then I would like to know if those two can be mixed.
Old 05-03-2006, 05:24 AM
fordman 460 fordman 460 is offline
fordman 460 is starting off with a positive reputation.
It is still no. Just because it was used in a fryer doesn"t change the specific gravity and they will not stay mixed.
Old 05-03-2006, 08:46 AM
Phydeaux88's Avatar
Quote:
Vegetable oil is vegetable oil. WVO = used SVO.
Old 05-03-2006, 11:07 AM
I get that they don't mix, but what difference does it make as long as I have the heating system to liquify the svo/wvo? Won't they still ignite in the combustion chamber?
Old 05-03-2006, 11:24 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
It separates in the tank with the different gravities. Until well mixed by truck movement.
Old 05-03-2006, 11:28 AM
Phydeaux88's Avatar
If you run WVO or SVO it is imperative that you start up and shut down on straight diesel. The only way to assure that will happen is two seperate tanks and essentially seperate fuel systems; diesel to start and shut down VO to run. Failure to do this can produce early engine failure. If you just mix the two in a single tank it will seperate into two layers. Your truck will be running on which ever layer is at the tank pickup at any particular moment. If it happens to be the VO layer when you shut down there is a very good chance you will have a lot of trouble getting it started again.
You need to ask a VO expert about using VO the sponser of this forum is Lesk WVO conversions. they have a link at the top of this thread. You can also get hold of them by starting a new thread titled "Questions for Lesk WVO"
Old 05-04-2006, 04:28 PM
Thanks for all the imput and patience with my question, but I guess I'm not presenting this clearly.
If I have two tanks, one with bio or #2 and one with svo and appropriate pre-heater lines, why can't I run bio/#2/svo through the heated line,as long as I do the start-up/ shutdown on Bio or #2 from the first tank? Is there a problem running bio or #2 through the heated svo line?
The situation I imagine is finding a cheap(haha) price for#2 while on the road and wanting to fill up the second tank that may have some residual svo in it.
Old 05-04-2006, 05:04 PM
Phydeaux88's Avatar
Hmmm little different scenario there. I have been told that once you use a tank for VO you should never put Diesel in it again. I dont know why.
Once again I suggest you contact Lesk WVO to get an answer to that question.
My thoughts are pick a system and go with it. Any time I have watched someone try to embrace multiple paths to the same objective it ended up costing them in the long term.
I guess my question is if you are going to run Bio Diesel why bother with the VO at all it will essentially double your initial setup cost, may lead to problems, and is an unnecessary complication.
Just convert all VO into BD and don't worry about it if you find some one giving away #2 just smile and fill up your tank. Or mod your truck to run VO and dont worry about that occasional #2 bargain cause your never gonna find #2 as cheap as WVO.
Tags
tank, vegitable, waste
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
