Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-01-2006, 04:02 PM
viperguy viperguy is offline
Garage is empty, add now
viperguy is starting off with a positive reputation.
1st timer: I made soap not Bio diesel Help!
I tried to make a small batch of bio diesel from fresh canola oil and the end result wasn't pretty. Some one please tell me what I did wrong. I took 1 litre of fresh oil and heated it to 130f. While doing that I mixed 250ml of methanol ("Snap" gas line antifreeze, says contains methanol) and 4g of lye (Glug drain opener,contains caustic soda: sodium hydroxide) in a seperate container and shook the hell out of it until it dissolved. Then I mixed the oil and methoxide together and shook it for 3 minutes really hard. I let it sit for a day and a half and saw it separated with a carmel color glycerine on the bottom. I then drained it out the bottom and proceded to the bubble wash stage. I added a 1/3 water and put the bubble wash stone at the bottom. I let that sit for 4 hours before I shut it off. I let it sit till the next day and i would say close to half of the total mixture was pure creamy frothy white. I drained all the water out the bottom, it ran out just like pure water would, I then got frustrated and dumped it all out because it didn't look right. Where did I go wrong.
Do you think the lye or methanol I used wasn't pure enough??
I am very interested in learning how to do this the right way.I plan to build an appleseed processor.
Another question: I am in Seattle,WA, does anyone know where I can buy methanol and lye (KOH) in bigger quantites. Like 55 gal of methanol???
Thanks
  #2 (permalink)
Old 05-01-2006, 08:22 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Thanks
First welcome to FTE Your first stop should be: http://www.biodieselcommunity.org
The answer to your questions.............................
#1. Drain cleaner has aluminum and magnesium, that will KILL the reaction. Use 98 percent KOH or NaOH, Red Devil Lye can be used for small test batches.
#2. 1 ltr oil only requires 200ml of methanol.
#3. All oils require a base amount of 5gms/lye per liter + titration. New [ unused ] oil requires approx 20 percent over the base amount. You should have used 6gms of Lye.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Tags
cleaner, drain, glug, naoh, opener, percent, seattle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
