Hi Guys, new here and just bought my first Diesel. It's a 1990 F250 With a 7.3L, and luckily its a 5 speed. I know it has a new head, glowplugs, and various other work done to it. What are some things I should know? It's a great running truck, and I love it so far. These older 7.3s without the turbo seem to get a bad rap for being on the wimpy side, is it true? Thanks....also, what are some good power upgrades?
Way I heard it, and no offense to the Powerstroke boys, but rumor on the street is that you can get the same horsepower out of the older 7.3 as the later Powerstroke by simply adding a turbo. I'm by no means a diesel expert, just what I heard.
A good power upgrade is a turbo.
You can do small improvements with exhaust and intake mods, timing and fuel mods.
But a turbo is the biggest bang for the buck.
Yes, a turbo will put you right up with the first generation Power Strokes for both torque and HP. 1999 is when they went over 235 horse if I remember right.
Check the coolant for SCA's (Supplimental Coolant Addaive) test strips are available at NAPA. This addative goes in the coolant to prevent cavitiation.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
You should be getting not much in the way of black smoke unless you are stomping on it. Just running down the road empty you shouldn't see any.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
I am looking at buying a 1990 F250 7.3 diesel with manual transmission. It is really bigger than I need but for the price I am considering it. What kind of gas mileage could I expect?
JayH, has the air filter been changed recently?
Black smoke is incomplete combustion of the fuel, which is a result of more fuel than it has air to burn. So at todays fuel prices you have to answer how much black smoke is to much.
Also if you live an an air quality area, the air police may tell you how much is to much.
themtb,
Need a little more info about the truck to even guess what the mileage would be.
Also your driving style will affect the mileage more that the truck equipment will.
__________________
Thanks Guys, the black smoke usually occurs when shifting. Maybe cause I'm still getting used to it? But I can tell that when I stomp on it a bit more, there is more smoke. There isn't any when I'm just cruising. I will check out the Air Filter though. I was thinking the Banks turbo too, but I'll do my research. I saw earlier, that somebody said they could figure my gear ratio by the various rpms, what would about 1600rpms at 45mph in 5th or overdrive be?
__________________
B5 soydiesel user
Sirius radio
__________________
B5 soydiesel user
Sirius radio
