Horn problem
Horn problem
[updated:LAST EDITED ON 06-Jul-02 AT 06:11 PM (EST)]I have a 69 f-250 CS. and the horn isn't working. I have the original dealers book and it says that the horn is on a circut breaker with the back-up tail lights and the headlight switch. I have removed the dask and speedo cable to access this area. Problem: I don't understand the switch. Does this Circut breaker re-set or is it time to replace. I have traced all the wiring to the horns and all looks good. I had someone depress the horn while i had a test light and it appears to have no voltage ????
After reading another post in June there might be a relay. any help on where to look and if I might replace it ?
Horn problem
The horn should be on a Fused circuit (NOT a C.B.)with something else like the radio or something.The Horn relay on later models was attached to the inside firewall ,left side,above the brake pedal.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
FTE Adminstration
[/font]
[/font]
Horn problem
The horn relay is right next to the starter solenoid. You should be able to hear it "click" when you tap the horn button.
Forget the power from the headlight switch, that's only good for the F500-F750 trucks, the shop manual is misleading.
There is no fuse in the system for the F100-F350 horns. Power comes off a ring lug on the battery side of the starter solenoid and goes to the inside terminal of the relay (fat yellow wire). The outside terminal of the relay is the switched power that goes to the horns (fat yellow w/green stripe). The lone terminal on the far side is the relay wire that goes to the horn button (skinny black wire) and is looking for a ground.
Barry
Barry
Horn problem
Thanks for showing up Barry.
At least I didn't suggest to look in the Trunk.
FTE Adminstration
[/font]
[/font]
FTE Adminstration
[/font]
[/font]
Horn problem
Brian, Dennis & Barry, I have found grounding to be a culpret as well sometimes. If the wire is hot at the steering wheel horn ring, then the ground is likely bad. We replace engines and don't replace the ground strap on the firewall, also there is a ground around the rag joint. I made a loop from one side to the other with a 2" piece of wire on my blue truck and the horn blows loudly every time now.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
John
jowilker email me
