oil pressure - Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
oil pressure
Old 04-30-2006, 06:20 PM
dnmccy1 dnmccy1 is offline
dnmccy1 is starting off with a positive reputation.
Question oil pressure
on my 87 f-150 351 h. o. when istart it up it has 60 psi of oil pressure but after it gets up to operating temp it drops to about 25 psi and sometimes when you pull up to a stop sign it only reads about 10 psi could i have a bad guage or should i replace the oil pump any answers would be appreciated thanks
Old 04-30-2006, 09:29 PM
fairmontman fairmontman is offline
fairmontman is starting off with a positive reputation.
I have heard the gauges used in the trucks were not always accurate,you might want to check oil pressure with a mechanical gauge off the engine and see what it is,I had a 78 460 that would read low oil pressure after warmed up, I put a oil pressure gauge on the engine and pressure was within specification.Are their high miles on the engine.
Old 05-01-2006, 06:07 AM
i put a new set of guages in it because the factory guages wasn't reading right it's got 166k on it but it had new main bearings and cam in 1999
Old 05-02-2006, 10:58 PM
Oil pump could be getting weak with that kind of miles
Old 05-03-2006, 05:37 PM
i'm going to try and put auto- meter guagues in and get rid of the sun pro ones that are in there and i'm going to run copper line for the oil pressure instead of the nylon tubing.
Old 05-03-2006, 05:39 PM
but if that don't work i'm going to put in a new pump
p. s. old fords never die they just go faster!!!
AirDog 2 PSI climbs, performax gauge betrayz 6.0L Power Stroke Diesel 2 05-27-2012 01:52 PM
86 302 EFI low oil pressure 86stepsideF150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 06-28-2010 09:23 PM
460 oil pressure stepside64 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-05-2004 06:34 PM
low oil pressure ?? oil cooler bad ?? kitsapcountychopper Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 04-05-2004 08:56 PM
oil pressure drops at high rpm butchs38 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 21 08-25-2003 03:19 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
