Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-29-2006, 05:13 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Garage is empty, add now
Fullcrew7.3 is gaining momentum as a positive member of FTE.Fullcrew7.3 is gaining momentum as a positive member of FTE.
Metals and Bio-d
I know that you aren't supposed to use copper or alluminum with WVO, but what about bio-d? Are the restrictions that same? What are some of the other guys using? is it all mild steel piping? If so, what size/gauge and how are you setting up your coils in your tanks? I have a slip tank for this set up and want to get it firgured out before I start buying, cutting or welding.
Thanks
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW, DIY 4x4 conversion, 4.10 gears, Sky 3" RSK, DIY 4" exhaust, 3" diamond eye DP, SC 1705, Stage 1 Rosewood sticks, Valair SMF, SD I/C, 37/12.50/16.5 wranglers and some more DIY stuff
  #2 (permalink)
Old 04-29-2006, 05:32 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Thanks
Anything but copper is ok. If you blend to B-80 in winter you do not have to heat the tanks at all.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 04-29-2006, 06:52 PM
bentring bentring is offline
bentring is starting off with a positive reputation.
What temps are you referring to fabmandelux? Also, please check your private messages fabmandelux.
__________________
2WD '93 F250 7.3L E4OD
  #4 (permalink)
Old 04-29-2006, 07:50 PM
1935 Ford pickup
Quote:
So far I have had no problems with B-80 down to 12 deg F. In the last 2 years that is the lowest temps we've had. B-50 should be good to 0 deg according to the cold tests i've done.
The answer to your PM is yes.
FABMANDELUX.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
