Wiring diagram for a 1970 Ford F-100 - Ford Truck Enthusiasts Forums
Old 05-28-2002, 03:00 AM
musmly65 musmly65 is offline
musmly65 is starting off with a positive reputation.
HELP!
I need to get my hands A.S.A.P., on a wiring diagram for my ford f-100.
My truck has some obvious short, somewhere. My battery exploded while the truck was off. The new battery smells like sulfer now which is what it smelled like before the last battery blew up.
I have replaced the altenator and voltage regulator, twice.
The battery keeps charging even when the truck is not running.
Can anyone give any suggestions or advice to find a wiring diagram that maybe I can get off the internet?
I have looked all over the net and have come up with nothing so far.
I really need something that I could download and print.
I would be willing to pay for this info. it anyone could help.
Thanks, Musmly65:-(
Old 05-28-2002, 03:30 AM
sparky's Avatar
sparky sparky is offline
sparky is starting off with a positive reputation.
Are you sure the battery is charging when the truck is off? If so you have to patent that system quick....free power
Are you sure it isn't discharging? Or possibly even a dead short to ground causing the battery to discharge so quickly it is burning up?
Sparky
Old 05-28-2002, 06:29 PM
IronSled IronSled is offline
IronSled is starting off with a positive reputation.
I agree with musmly65 on this one. Take it from me Im an electronic tech batts do not charge them selfs. Sounds like you have a short some where off of your main power. Check all of your heavy (4/6/8gage)wire for signs of wear,melting, breakage whatever...if you find nothing there check at the solinoid and coil and work your way back through the firewall looking for rubs.
Old 05-28-2002, 07:42 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
Welcome to the site Musmly65! Sorry to hear about your wiring problems. Iím starting to put some diagrams in my gallery, click on it and see if they help you out any. Exploding batteries are dangerous and make a big mess, wear eye protection and hose down all that battery acid.
Barry
Old 05-29-2002, 12:33 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Ford Charging system.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old 05-29-2002, 10:40 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
Dis-connect that battery pronto. Put a 12v test lamp (a tail lamp will work) between the pos bat post and the pos battery cable. If something is drawing current, the lamp will light. Pull fuses and unplug connectors until the light goes out. Be aware that it may be an intermittent problem if a wire with a bare spot starts shorting to ground while driving.
Old 05-30-2002, 12:52 AM
sparky's Avatar
Actually that test will work alot better if you use the negative battery wire instead of the positive
Sparky
Old 06-28-2002, 07:10 PM
Old 07-18-2002, 10:47 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Maybe the problem was never found, but, for anyone else here is a suggestion. If your cable from the starter relay to starter is worn through and resting on the frame AND you have a bad solenoid it is possible to short out with the truck off or IF you have a bad ignition switch.
If the battery exploded from the short, there are only a few cables and items that can drain that much current without total melt down. Your starter, starter cables, and maybe a bad alternator are about the only things up to ARC welding.
65-66 Ford F-100 wiring diagram needed. jasindude1 1961 - 1966 F-100 & Larger F-Series Trucks 0 04-13-2016 06:06 PM
Need wiring diagram toolmanx Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 02-21-2012 08:16 AM
65 ford f100 wiring diagrams 65stakebody 1961 - 1966 F-100 & Larger F-Series Trucks 1 12-31-2011 04:46 AM
Lots of electrical problems joejoesgotya 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-27-2010 10:15 AM
1971 F-100 4x4 360 wiring diagram anyone?? FordManStan 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-11-2005 03:18 AM
Tags
1970, 70, charging, coil, diagram, f100, f250, ford, free, regulator, series, system, voltage, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
