E85 Gas Mileage
Our owner's manual in our 04 Explorer says to expect up to 35% less mpg. However, we used it a few times and really didn't notice too much of a decrease, about 1-2 mpg. That little of a difference could have been due to accelleration or higher speeds on the highway. We'd fill up more often with the E85 but the closest station to us is about 30 miles away. I'm sure there will be a lot more stations offering it soon, especially with a lot of the new cars having it as an opiton.
Corn Fuel
It's a ethanol blend of fuel, 85% ethanol hence the name and 15% unleaded. No, not anyone can use it, you have to have special plastics and various other internal parts in your engine as the ethanol is more corrosive on conventional engines. Haven't you seen the Ford commercial where the F150 pulls up along side a cornfield and the driver gets out and walks a few rows in and grabs and corn stalk then sticks it in his fuel tank and proceeds to fill up?? Seems like every other commercial here in the midwest.
Check out http://www.ethanol.org/e85.html .. all you ever wanted to know about E85.
Hey Red, I don't think you can put E85 in your truck. I don't recall hearing E85 going into any F150's until the new model. In 2002, only a Range and a Taurus had what they called then, FlexFuel.
So don't go putting it in the truck unless you know for 100% sure your truck can take it. If you do, you'll have to have it towed in and drained. E85 requires extra "sensing" to see that it has high alcohol content and advance the timing. Without that timing advance, the truck may not even start. Or at least run terrible. Not to mention, it could eat some components that aren't rated for that high of alcohol content.
Okay, repeat after me:
DO NOT USE E85 UNLESS:
A) YOU HAVE A FLEX FUEL VEHICLE
or
B) ARE PREPARED TO SUFFER THE POSSIBLE NEGATIVE CONSEQUENCES.
Note that I used all caps on purpose. This wasn't an accident.
There is alternative fuels sub-forum with lots of info. Do some research there so you understand what may or may not work.....
or
It can be done with a few mods
Originally Posted by BIGREDFX4
thanks for the help guys. looks like I won't be filling up next to work when the station starts using it. I will continue to fill up in Kansas.
Dan
Ethanol can degrade many plastics and seals over time in a fuel system that was not designed for it.
I'd keep that in mind - just because it seems OK for a while doesn't neccessarily mean that things will be fine forever.
In the end, it's up to the individual to determine if the potential risks are worth it.
bcf
10-28-2003 04:46 PM
Pastmaster
10-28-2002 06:40 AM
