Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-25-2006, 12:39 PM
BeltDriven is starting off with a positive reputation.
turn key, no start.
Ok, I went to start my truck today and nothing engine won’t turn at all. I check and clean the battery and all connections to starter, starter relay, and battery. Also checked the headlights and cab light, they both work but the gas gage and windshield wipers do not. now im thinking the starter relay is bad. I put the truck in neutral, turn the key to run position. I disconnect the battery side to relay and arc it to the starter side and viola engine starts to turn. I go buy a new starter relay install it and nothing again, wont turn at all unless I arc battery side to starter side. Only other thing I can think of is the actual ignition switch but not sure how to test or replace it. Ohyeah the truck is an 84 F150 I6 manual any help would be greatly appreciated as I am at a stand still for now.
Thank you for your time,
Don
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-26-2006, 01:28 PM
Wink
Never mind, it's fixed.
  #3 (permalink)
Old 04-26-2006, 03:16 PM
quicklook2's Avatar
quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.
no hint as to what it was to help someone else?
  #4 (permalink)
Old 04-26-2006, 07:54 PM
Oh, sure. I found two corroded wires near the battery. They were the culprits.
Went threw many tests and replacing things before I found the wires. A painful reminder to always check the simple things.
Cheers,
Don
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
