Erratic RPM needle
Old 04-25-2006, 11:30 AM
Hartwa's Avatar
Hartwa
Hartwa is offline
Erratic RPM needle
I have an 02 F150 Supercrew with a 5.4L.
Sometimes I notice when I am crusing about 55-65 that the tach needle flutters from 1500 to 2000 RPM's while at a constant speed. The needle is moving but the actual RPM's on the engine is at a constant idle...I am sure that the engine is at a constant idle since you can tell / hear when it shifts down.
I am sure that this is a problem with the tach itself but I am not sure where to begin to fix it...I have not pulled it out yet but I am sure that it is all electronic.
Any ideas would be appreciated.
Hartwa.
Old 04-25-2006, 12:53 PM
pronstar's Avatar
pronstar
pronstar is offline
Often, things like this are due to a faulty ground, so your gauge may be OK.
Old 04-25-2006, 03:04 PM
Hartwa's Avatar
Hartwa
Hartwa is offline
thanks Pronstar
Any idea where the instrument panel gets ground? I did just remove my battery cables to work on something else. Could the negative cable have a bad connection?
Old 04-25-2006, 03:35 PM
machnegative's Avatar
machnegative
machnegative is offline
I have an erratic tach on my 1997 f-150 and haven't found the cause either. I have been looking around for info on the cause, but haven't found it yet.
Old 04-25-2006, 03:36 PM
mach10533's Avatar
mach10533
mach10533 is offline
the little small ground wires that hook to the main ground cable that go over to the body often get broken inside the insulation or corroded and could cause problems.
rustyfuryiii
Modular V10 (6.8l)
07-10-2007 08:48 PM
Hartwa
1997 - 2003 F150
01-22-2007 03:27 PM
Hartwa
1997 - 2003 F150
01-14-2007 10:24 PM
Hartwa
1997 - 2003 F150
08-29-2006 01:10 PM
ROKRAWL
1966 - 1977 Early Broncos
05-12-2003 09:09 PM
Quick Reply: Erratic RPM needle
