Air Starter - Ford Truck Enthusiasts Forums
Air Starter
Old 04-25-2006, 10:46 AM
wbhinton's Avatar
wbhinton wbhinton is offline
wbhinton is starting off with a positive reputation.
Air Starter
Has anyone ever fitted an Air Starter to their truck to replace the stock electric starter?
An air starter seems like it would be more reliable, as long as you have an air supply... and they sound pretty slick when they spin an engine.
WB
Old 04-25-2006, 01:59 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
I've only heard one once a long time ago, and yes it sounded really cool. And after I got over the sticker shock, it occurred to me that it would be some serious bragging rights. It would be a good reason to shut off the truck when you go to a dyno meet.
Old 04-25-2006, 02:05 PM
little tow little tow is offline
little tow is starting off with a positive reputation.
The fleet where I worked had some air starters many years ago but proved to be troublesome and expensive. Where fire safety is a concern or mandated that non electrical equipment be used may require air starters.
Old 04-25-2006, 02:09 PM
wbhinton's Avatar
The reason that I ask is that, in the oil field all of the big CAT engines have air starters... and boy do they scream when they crank that motor....
thought it might be kinda cool to have in a PSD
Old 04-25-2006, 02:24 PM
BowDown's Avatar
BowDown BowDown is offline
BowDown is starting off with a positive reputation.
How much are they? Do you use electric air compressors and a tank to power em?
Old 04-25-2006, 03:35 PM
wbhinton's Avatar
not sure on how much the starter would cost...
You would have to run an small compressor and a small air tank to power the starter. Maybe a .5 to 1 gallon tank. And just wire the compressor to kick on after the truck has fired up.
I looked at some earlier that operate at 90 psi and only pull .25 cfs (cubic feet per second)
Old 04-25-2006, 04:21 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I heard that air starters make good statistics for the Army.
When they have alarm, with 3000 psi air tanks they can make outside the gate without starting the engines.
That's what statistics count.
Old 04-25-2006, 04:22 PM
Hiflyer746 Hiflyer746 is offline
Hiflyer746 is gaining momentum as a positive member of FTE.Hiflyer746 is gaining momentum as a positive member of FTE.
can we get them?
Hey guys, this sounds interesting. . . is this something we can get ahold of? I would be interested in it, ANybody let me know, Thanks,
Timmy
Old 04-25-2006, 06:55 PM
wbhinton's Avatar
There are two manufacturers that could help out on the air starter idea...
ASC- ascairstarter.com
AM airstarters- amairstarters.com
Take a look and let me know what you think
Old 04-25-2006, 06:58 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
what do air starters sound like? it seems like it would be pretty easy to swap in if it was a bolt-on item. does the military use T444Es?
Old 04-25-2006, 07:08 PM
wbhinton's Avatar
You know how an impact wrench sounds? Its kinda like a cross between and impact wrench and a singing turbo.... Louder and higher pitched than an impact and louder and deeper than your turbo. Sharp and crisp sound.
The ones used for those monster 3512's is deafening...
You will never forget what one sounds like when you first hear it go off. I hit the deck because I thought the SOB was about to blow-up, all of the experienced hands laughed at me :-/
Old 04-25-2006, 07:16 PM
BowDown's Avatar
Muuuhahah!
Click here for a crappy clip, but all I could find. http://www.citlink.net/~tcrandall/RoadWarrior.wmv
Old 04-25-2006, 07:22 PM
ha! that sounds cool!
Old 04-25-2006, 07:23 PM
BowDown's Avatar
Here's another. Hard to find. http://www.towboatjoe.com/starting.mp3
Old 04-25-2006, 07:30 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
Air start systems work well on large (very, very large) diesel engines that a starter motor could not turn over.
The air start system pipes high pressure air to each cylinder from a distribution manifold and though air start check valves to each cylinder. The systems I'm used to run with 175 psi starting air pressure and will spin a diesel engine until it starts.
After maintaining the air start systems, I'm glad that my truck has a starter motor....
Lou Braun
How much cranking c mobley 1999 - 2003 7.3L Power Stroke Diesel 34 08-22-2016 08:00 PM
2001 F150 won't start 5.4 66with352 1997 - 2003 F150 10 08-10-2016 12:51 PM
89 F250 no crank. user_zero Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-18-2016 09:19 AM
1992 CF8000 7.8 Auto Air Starter to 12 Volt Jo Diesel Large Truck 2 03-30-2016 04:50 AM
93 F-150 won't start when hot tbswitser 1987 - 1996 F150 & Larger F-Series Trucks 8 10-23-2008 11:09 AM
Tags
302, advantage, air, f250, f350, ford, power, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
