Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-25-2006, 10:30 AM
81fordf-250 81fordf-250 is offline
Garage is empty, add now
81fordf-250 is new and has a neutral reputation at this point.
Post Pro's and Con's of Methanol
i am also doing a paper on the alternative fuel called methanol. I would like to know some good and bad things about the fuel and cars that run on it?
  #2 (permalink)
Old 04-25-2006, 01:32 PM
fellro86's Avatar
fellro86 fellro86 is online now
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Main problem with methanol is it's corrosiveness, it is pretty tough on fuel lines, aluminum, plastics, anything rubber...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 04-25-2006, 01:59 PM
whodat54321 whodat54321 is offline
whodat54321 is starting off with a positive reputation.
check the wiki:
http://en.wikipedia.org/wiki/Methanol
  #4 (permalink)
Old 04-26-2006, 10:32 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
The good things are very high octane, so you can run very high compression ratios and/or turbocharger boost, like in Champ Car racing engines. Methanol is most commonly made from natural gas (Methane, hence the name), so it is usually cheaper to make than ethanol.
Jim
  #5 (permalink)
Old 04-26-2006, 11:07 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Racers that use it drain and flush their fuel system after every race.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #6 (permalink)
Old 04-27-2006, 12:56 AM
J6Szczecin J6Szczecin is offline
J6Szczecin is starting off with a positive reputation.
I believe methanol, is a wood based alchohol, as opposed to grain, and is highly toxic if consumed.
  #7 (permalink)
Old 04-27-2006, 11:37 AM
While it used to be "wood alcohol", modern manufacturing is different. One reason for E85 and not pure ethanol is that 15 percent gasoline is needed to make it toxic, so that people wont drink it and it doesnt have to be taxed as drinking alcohol. All alcohols have an affinity for water, and that is the main cause for the corrosion problem. Proper selection of fuel system materials is vital. If you are talking about someone converting an existing gasoline car, you have a problem. If the discussion is about a factory-built alternative fuel car, no real problem.
Jim
  #8 (permalink)
Old 04-27-2006, 10:13 PM
scucci's Avatar
scucci scucci is offline
scucci is starting off with a positive reputation.
1: Methanol has a stoichiometric air/fuel ratio of 7 to 1 and so gives less than 50% the fuel mileage of gasoline.
2: Methanol is hard to light off - we used to squirt gas in the injectors of my dad's nascar modified to start it up.
3: used to be that methanol required neoprene hoses because of rubber deterioration.
4: methanol has fewer BTU/lb heat content and all horsepower increases were due to high compression (13-1 to 15-1 in our case)and increased spark advance. So it will give less horsepower on a stock engine.
4: Methanol burns with a blue flame that is almost invisible so is actually more dangerous. H2O is the way to put it out.
5: Used to be made by charring wood and collecting and condensing the vapors. Don't know what modern method it is made by.
6: Most likely it is not going to be available in large enough quantity to be affordable.
Hope I didn't miss anything.
Scucci
  #9 (permalink)
Old 04-27-2006, 10:38 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
Actually, Ethanol has Toluene added to denature it. At least that much.
I believe at the plant, the MSDS and lab test sheet we get before unloading the tanker states 5 gallons Toluene per 200 gallons of Ethanol.
Methanol is quite poisionous and judging from the supply boats that docked around the boat I worked on, it ain't no joke to deal with. Knowing the dolts who like to keep cellphones and cancer sticks (cigaretes ) nearby, that's a Darwin Award waiting to take you along for the ride.
http://www.bu.edu/es/labsafety/ESMSD...l#anchor888417
Flash point 12* C...sexy.
Tags
bad, cons, good, methanol, things, truck, unloading
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
