A/C blows warm when driving...but... - Ford Truck Enthusiasts Forums
Old 04-24-2006, 10:38 PM
Pompanosix Pompanosix is offline
Pompanosix is starting off with a positive reputation.
...but blows cold when I'm parked and idling. I can't figure it out. I have a 94 f-150. It is a r-134 system. The mechanic who did the a/c in the first place can't figure it out. I've been back to him at least 5 times to no avail. I bought all new parts for it. He's absolutely clueless at this point. Has anyone had this problem before? Any thoughts would help.
Old 04-25-2006, 08:18 AM
jtmerritt jtmerritt is offline
jtmerritt is starting off with a positive reputation.
At higher rpms the suction side pressure will go down and possibly in your case low enough that the low pressure switch is opening. What are the high and low side pressures at 2000 rpm and at idle?
John
Old 04-26-2006, 05:29 AM
jt,
thanks for your input. I'll try to get all that info later this week. What I'm doing is trying to help this darn mechanic to fix it so whatever info I get from here, I pass it on to him. After going to him 5 times, I'd just as soon help him at this point get it fixed because yesterday, with the humidity factor, it was up to about 97 deg here in s.florida. I'm never going back to this guy, but for now, I need my a/c fixed.
Fill me in some more on this low pressure switch thing. I don't know much about a/c. The fact that the suction side pressure goes down makes sense to me, but what does the switch do exactly and where is it located. When is it supposed to close and open under normal circumstances? thanks much.
Old 04-27-2006, 08:42 AM
The low pressure switch should be threaded into the accumulator tank or line going into the accumulator of the suction side coming out of the evporator. It is a two wire connection and the switch threads directly into the fitting and has an o-ring for sealing. It is a schrader valve type of switch, like a tire valve, which means you can remove the switch without losing the freon. The switch is designed to open when suction pressure drops below a preset point, usually about 30- 35 for an R-12 system. If the R-134 charge is a little low the suction pressure will drop below the preset and shut of the compressor, which is what I think is happening to you. Also with R-134 freon many times the low pressure switch is set lower, like around 20 psi. Some low pressure switches are adjustable so remove the connector and look down into the switch connector and see if there isn't a small adjustment screw. If not you can replace it with one from NAPA. If it does have an adjustment, turn the screw CCW for lowering the pressure. Make small turns like an 1/8 of a turn to adjust. You have to have guages attached and engine rpm needs to be at about 1200 rpm to set the adjustment properly and also to check high and low side pressures. What are your high and low side pressures at 1200 rpm and at what is the ambient air temp at the front of the condensor? If youcan get me these I can probably help you through this. I said 2000 rpm in my earlier post when I meant 1200.
John
Old 04-27-2006, 10:58 AM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
are you in NORM AC or MAX AC, Max AC recirculates INSIDE air, Norm AC brings in Outside air.
Cools 97* air to 40* won't happen period.
Best ANY AC can do is cool it 30* that is why it needs to cool Recirculated air.
Is your recirculate on air door operating correctly?
Old 04-28-2006, 12:52 AM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
Could be the recirculate door vacuum servo is leaking.
Have you noticed whether you get cold air on deceleration? (high engine vacuum condition)
Old 05-06-2006, 09:56 AM
sorry it's been a while....been extremely busy.....
hhot71,
the recirculate door is definitely working. I checked it myself and felt the difference when I turned the switch. I actually never knew if it worked because since I've owned the truck, the switch has never seen "norm ac". It's just to damn hot.
jt,
thanks for all your help. the mechanic informed me he replaced the switch and made adjustments and that fixed it. Ahhhhh, and life is good. thanks everyone.
Old 08-20-2006, 06:39 AM
bigal6030 bigal6030 is offline
bigal6030 is new and has a neutral reputation at this point.
I have a similar problem but just the opposet. My A/C will work fine them the cold air turns normal (not warm) If I rev the engine to 2500 rpms it begins to blow cold again.
Can someone help
AL
Old 08-20-2006, 09:35 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Can someone help
AL
Check your charge level.
Review previous A/C system posts for ideas.
Steve
A-C port for recharge location? Molonlabe1776 6.0L Power Stroke Diesel 17 06-03-2016 12:14 AM
A/C max blows out defrost. mshargrave23 1999 - 2003 7.3L Power Stroke Diesel 12 09-15-2013 12:02 PM
2005 F250 A/C Ext Temp reading 50 all the time on head unit tjrl_popo 6.0L Power Stroke Diesel 19 06-29-2013 07:59 PM
Another A/C post...but its not the air gap soggybottom 1999 - 2003 7.3L Power Stroke Diesel 4 06-07-2011 12:47 PM
Hot air blowing into cab gwp36530 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-26-2004 07:02 PM
Tags
2002, 2003, ac, air, blowing, blows, bronco, cool, f150, f350, ford, hot, idle, truck, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
