Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-24-2006, 08:20 PM
pdqtimetrialer is starting off with a positive reputation.
Leaking Timing Gear Cover
How hard is it to replace the timing gear cover gasket? I have a '95 F-150 with 145k, and their is an oil leak from around the timing gear cover that has gotten worse. Should I replace the timing chain and the gear while I'm at? What special tools might be required?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-24-2006, 08:48 PM
javi2001's Avatar
javi2001 is starting off with a positive reputation.
Well, 300s use timing gear not chain.
You have remove all front of the truck, like front grid, AC condenser, radiator and the worse the vibration damper also... it has a 15/16" bolt very hard to remove. Then you can remove the cover, will need the gasket and the crankshaft seal.
__________________
Javi2001@cantv.net
Venezuela
4.9L carby +E4OD +1356 Electric shift T-Case + WARN Auto hub's +Baumman TCS controller, F150, 4WD, 1986!!! will be MFI shortly
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
