Industrial Engine ID
In the orchard I work in we dont know really what engine one of our wind machine has. So I am hoping that someone out there can help me. We know it is a old motor weve been told both 292 and 332. But here are the numbers off the Id plate.
Serial: 4645-E14KB
Type: B8PK-6003-3
Options: S0-742
Serial: 4645-E14KB
Type: B8PK-6003-3
Options: S0-742
292 and 332 are CIDs for the Y-block; consistent with the B8 ('58) prefix.
Cool motors, check in at the Y-Block forum for more info:
https://www.ford-trucks.com/forums/f...splay.php?f=56
Ok, it's a Y-block, or a Lincoln Y. Similar to each other, but not identical. Not much interchanges, either.
At this point, to tell them apart, look at the exhaust manifold bolts or studs. If all the bolts are in a straight line more or less & at the same height (if you know what I mean), it's a Y-block. If the bolts at the very ends of the exhaust manifold are distinctly higher than the middle bolts, it's a Lincoln Y.
Like this: *.....*
The Lincoln Ys were also used in medium & heavy trucks, so it's quite likely they were used for industrial powerplants as well.
If it's a Y block, it should be a 292 as supposedly they were all that was offered from '58 on in the US, but according to one member of the board, 312 CI Y blocks were installed in some trucks later on, (or warranty replacement, I forget which) without Ford stating that they were 312s instead of 292s.
If it's a Lincoln Y, it should be a 332, I believe; the smaller Lincoln Ys were dropped by that time. I won't swear to that though, but some of the other board members should be able to confirm/deny.
Personally, that's one of the few things I dislike about the Y; harder to adjust points when they're in the back, just like a GM.
Like this: *.....*
hi there.. I live in Wenatchee, WA and we just pulled a Lincoln Y block off the tower of an orchard wind machine! like you.. we are trying to Decode the ID tag.
if you have learned any more about these numbers.. I'd sure like to hear about it. We would really like to just know the year it was built. thanks for any help you may have to offer
The Lincoln Y exhaust bolts have a zig-zag pattern. It is not just the end holes that are different.
The lincoln intake ports are side-by-side, like a Chevy (and many other engines of the early '50s).
The thermostat housing is on top of the intake, mounted horizontally
The Ford Y has exhaust holes which are in-line.
The Ford intake ports are stacked, one on top of the other, more like a pair of Chevy ports turned 90 degrees.
The thermostat housing is on the front of the intake, mounted vertically.
There are many other differences, but these are probably the easiest to spot and will help to narrow down the options
Verticle thermostat housing
thanks
77f250kid
17
09-01-2017 03:19 PM
Gambler72
05-30-2017 09:03 PM
