Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-23-2006, 09:38 PM
sgrol sgrol is offline
Garage is empty, add now
sgrol is gaining momentum as a positive member of FTE.
Optimum temp for WVO and other ??
1. Is there an optimum temp for the wvo to run in a PSD?
2. Is there a temp that's too hot ?
3. How long can you store wvo from the restaurants? ( I would like to stock up now so when I get converted I'll have a supply going.) Thanks to anyone for replys.
__________________
Steve
2012 F 350 6.7 KR 4x4, SEIC Mod, Flagpole delete, Jimmi Jammers, McGard Tailgate Lock, HID
2000 F 250 7.3 4x4 CC
  #2 (permalink)
Old 04-23-2006, 11:42 PM
Orpackrat Orpackrat is offline
Orpackrat is starting off with a positive reputation.
I think but do not know for sure that you do not want a temp above 200 degrees but about 150 degrees. FABMANDELUX is the one to ask, he know much more than I do.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
Converting to run WVO, will also convert to custom flatbed with pop-out 5th-Wheel, thinking about making custom popup camper-tent for it as well.
  #3 (permalink)
Old 04-23-2006, 11:45 PM
Click the image to open in full size.Click the image to open in full size. Oops I put above 200, I meant below 200 and above 150. Click the image to open in full size.Click the image to open in full size.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
  #4 (permalink)
Old 04-23-2006, 11:47 PM
Click the image to open in full size.Click the image to open in full size. Oops again, I misread my first post,
mabe it is time for me to go to bed.Click the image to open in full size.Click the image to open in full size.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
  #5 (permalink)
Old 04-24-2006, 04:23 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
#1 150-160 F is the number most shoot for. In a PSD that is hard to measure sine the injectors are in the heads a long with the fuel rails. Most think the PSD is the perfect engine for WVO. It has built in fuel line heaters. I get oil going into the heads at about 145-148F so I have to assume I'm picking up even more heat from the heads.
#2 In a PSD there probably isn't a too hot temp. Since we don't have an IP we don't need to worry about overheating it. But, how your heating it to that temp could be an issue. If you use some sort of electric heater to heat it you always want a filter of some sort after the heater.
#3 Not sure I've read 6-9 months if it's unfiltered much longer if it filtered and dewatered. I use mine pretty fast so I've never have any around more then 2 months.
Tags
4cyl, diesel, engine, heating, optimal, optimum, perfect, temp, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
