Trans slipping 1st gear
Old 04-23-2006, 09:00 PM
jfonod's Avatar
jfonod
jfonod is offline
I have a 97 150 with a 6 cyl auto. 124k on it. The trans started minorly slipping upon takeoff in 1st gear. All other gears shift fine. There has never been a fluid/filter job done on it and I am curious if this may be the problem or if it may be something more serious like a shift module. Can the fluid & filter be done @ home if I try to do this?? Thanks
Old 04-23-2006, 09:09 PM
G'sRed99F150's Avatar
G'sRed99F150
G'sRed99F150 is offline
My Buddy had the same problem with his 97 V6 F-150. Took it to a tranny shop, they ended up replacing some sort of solinoid for $200. Worked great for a while (2 weeks) then it started all over again.The funny thing was, he could drop it to 2nd from a stop, and it shifted perfectley. He took it back to the tranny shop, and of course they wanted to rebuild it then.He opted it out, it was a dump run truck, and he shifts it to 2nd at a stop, then to drive. I hope you figure it out.We did all of the fluid and filter change with no luck.Id change it first, it takes a couple of hours, every problem is different.
Old 04-24-2006, 07:07 PM
jfonod's Avatar
jfonod
jfonod is offline
I changed fluid and filter today and it seemed to help for about 20 miles,now it sits in front of my house and will not move forward at all. Seems like when I put it in drive,2nd,or first, it is stuck in neutral. Could it be possibly a shift module?
Old 04-24-2006, 07:26 PM
G'sRed99F150
I'd check and make sure it was full. It takes a lot of fluid, what fluid did you use? Check this thread out, and see if it helps.
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-436140-4.2%20tranny%20slipping">4.2 tranny slipping</a>
Old 04-24-2006, 09:55 PM
jfonod's Avatar
jfonod
jfonod is offline
I think i will give that a try, if that doesn't work I guess I have no choice but to drop it and put a different one in.
Old 04-24-2006, 09:58 PM
G'sRed99F150
Let me know how it turns out. Beats going to the tranny shop and getting nailed for two grand or more.
Old 04-24-2006, 10:45 PM
jfonod's Avatar
jfonod
jfonod is offline
Was wondering if anybody could shed lite on how to figure out these codes on my door jam for my tranny. I know it has 14 pan bolts and the pan says metric. any kind of info. would be greatly appreciated.
Old 04-25-2006, 07:39 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Go to the top of the page, select ARTICLES/SPECS, follow that, there is a section on codes and decoders that inludes the definitions for the door jamb stickers.
Steve
Old 04-29-2006, 03:39 PM
jfonod's Avatar
jfonod
jfonod is offline
Does anyone know of a website where I can find a parts diagram for my trans?
