Thumping front end when accelerating from a stop
Supposedly, another cause could be the tcase clutches and the fix is replacing the tcase fluid. My 00 4x4 has 67k on it; I replaced the fluid with synth at 30k, and just did it again in May 06 at about 65k miles. The noise went away both times. My thinking is that that awd engaging through the tcase on demand must wear the fluid out fast. Try changing it with synth or at least make sure that's what gets put in with a new tcase. It might work.
Originally Posted by EX40
I've used 4wd abt once since I've had mine. Would this still stand true? Even when I used it it was 4h or 4l.
Transfer Case
Hey there MY's was doing the same and I thought that it could be my U joints, or Axles or wheel hub Bearing, But it was my Transfer case Fluid was really low and havent been change since the truck was made, I change it and Boom.....!!!!! No more noise, just check to see your level of fluids....
Rays auto
1999 to 2016 Super Duty
09-06-2016 10:49 PM
