Racor CCV Filter
I didn't see a price anywhere, but looks interesting. However, I intend to build my own knock-out pot with a return to the intake to keep the odors in the motor, as I have en excursion. In a truck the current ccv mod would be fine but for the Ex I want to keep the system closed. Might mount the KO pot on the engine side of the AFE2.
Wes
Wes
Racor CCV Filter
I've heard of a few people that have installed the Racor system for the 7.3 & then had trouble w/ oil leaks & seals blowing out. I'd be careful w/ anything that might increase crankcase pressures especially if the engine's got some blowby to begin with.
I know Racor was looking at a redesigned filter for the 7.3L kit due to this issue. I was going to install one and then did a little research and decided against it.
DG
DG
I made my own system like that. I used a 4" chunk of exhaust pipe agout a 1' long. Welded some caps on the end and 2 90* metal elbows. I made a filter out of some metal sheet that was full of 1/8" or smaller holes. Put them on a steel shaft and spaced them about an 1" apart. Now the oil stays in the canister and the smell gets sucked back through the intake system. No more stinky smell!
Lancer that's a good idea.
Guzzle92 also made his own and took some pictures. http://guzzle.rbmicro.com/ccv.html
I will live with it cause I happy with the way it's keeping the intake tubes clean.
How bad is the stank? I have a Racor filter still in the box cause after reading here about how to make your own, I'm not sure if I'll use it or sell it on ebay. I was thinking of doing the 4" exhaust pipe section ,running the hose from the doghouse past the rear axle. Think I'll still get the stink?
joe blow
04-19-2011 03:43 PM
MoyockPowerstroke
07-17-2009 07:46 AM
Clint40
35
01-30-2006 05:10 PM
