Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-22-2006, 07:29 PM
jeffreystar jeffreystar is offline
jeffreystar is starting off with a positive reputation.
How do you remove door lock actuator??
I've searched and found some good posts on how to fix the actuator once it is out.
However I can not find a step by step guide on how to remove the actual actuator....
Can anyone link me or give me a good break down on how it is done?
I have thd door panel off and I'm stuck there.
I don't understand how to remove the door lock rod or how to get the actuator out.
Thanks!!
__________________
Jeff Austin
2000 F250 PSD
1994 Supra Turbo
  #2 (permalink)
Old 04-22-2006, 11:08 PM
ANYBODY!??? Please help if you know the steps.
__________________
Jeff Austin
2000 F250 PSD
1994 Supra Turbo
  #3 (permalink)
Old 04-23-2006, 01:35 AM
kanertop kanertop is offline
kanertop is starting off with a positive reputation.
I just performed this today
-remove inside door panel (2 screws)
-remove door latch screws (3 torx head screws)
-remove outer door handle (2 screws located through inner door) and disconnect the 2 linkages
-remove inside door handle (2 screws)
-drop actuator, disconnect electical and remove
__________________
2000 F-250 SuperDuty S/C,S/B,Lariat, 4wd, V-10, A/T,3.73LS
2005 Expedition, EB, 5.4L V-8, 4wd
  #4 (permalink)
Old 04-23-2006, 03:51 AM
Wow, thanks! I thought that was about what I needed to do, but with out knowing I was kinda stuck. THANKS A TON!
__________________
Jeff Austin
2000 F250 PSD
1994 Supra Turbo
  #5 (permalink)
Old 04-23-2006, 11:09 AM
Good luck on your project. If you have any other questions, just ask. I redid my lock actuators yesterday and now they work better than new.
__________________
  #6 (permalink)
Old 04-23-2006, 01:11 PM
OK
Ok but don't remove door latch?
OK, 2 10mm bolts or something, one top one bottom?
OK, What is this exactly and what is holding it in? Scews???
OK, drop the acuator and door latch as ONE assembly?? That's what I feel you are saying. Thanks!
__________________
Jeff Austin
2000 F250 PSD
1994 Supra Turbo
  #7 (permalink)
Old 04-23-2006, 01:42 PM
you will remove the door latch as one assembly in the last step. the actuator is attached to the latch
you are correct on the outer door handle
you remove the inner door handle so you dont have to disconnect it at the latch, it is much easier this way
good luck
__________________
  #8 (permalink)
Old 04-23-2006, 02:39 PM
Kanertop:
wow, done and done. That was a LOT easier then it looks. It took about 25 minutes from start to testing, I haven't put it back together yet because I wanted to take a break and post that your instructions were very helpful.
I think all I needed was to take the outer door handle off, from that point on the job gets a lot easier!
Somebody should do a detailed write up on this job!
When you were in there, did you clean and re-grease everything really well? That was my secondary focus. The operation of the door feels a lot smoother then the passenger door does. When that lock acuator goes out I'll give it this same treatment.
__________________
Jeff Austin
2000 F250 PSD
1994 Supra Turbo
  #9 (permalink)
Old 04-23-2006, 03:44 PM
I just wrote a cheap write up on my job. No pictures and it could use some improving. I'm going to post it, fill free to send me corrections.
__________________
Jeff Austin
2000 F250 PSD
1994 Supra Turbo
  #10 (permalink)
Old 04-23-2006, 04:08 PM
Jeffreystar,
I did clean and regrease all the gears. It looked as if the long, black gear had gotten hot at some point and needed it. Glad to have been able to help.
__________________
  #11 (permalink)
Old 07-25-2009, 04:30 PM
preparation_h preparation_h is offline
preparation_h is starting off with a positive reputation.
works like a charm
I found it far easier to take off the outside handle. It adds a bit of light into the door frame and it's easier to take off and put back on the outside door clamp.
Thanks again!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
