front turn signal lens busted
If I remember correctly, there should be two screws below the lens...between the bumper and the lens. Remove the two screws...and then gently pull the lens out. It will be tight...because the bulb socket harness is there too. So, before the lens comes out all the way, you will need to twist and remove the bulb socket.
Also...on the side of the lens...there are alignment pins. So watch for those with the install. Installation is the reverse...
Hope this helps...
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Hope this helps...
biz
NotURMailman
1999 to 2016 Super Duty
01-18-2023 06:39 AM
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
07-30-2015 01:44 PM
dieseldodgeguy
12-15-2013 09:50 AM
