1st timer: I made soap not Bio diesel Help!
Old 05-01-2006, 04:02 PM
viperguy's Avatar
viperguy
viperguy is offline
I tried to make a small batch of bio diesel from fresh canola oil and the end result wasn't pretty. Some one please tell me what I did wrong. I took 1 litre of fresh oil and heated it to 130f. While doing that I mixed 250ml of methanol ("Snap" gas line antifreeze, says contains methanol) and 4g of lye (Glug drain opener,contains caustic soda: sodium hydroxide) in a seperate container and shook the hell out of it until it dissolved. Then I mixed the oil and methoxide together and shook it for 3 minutes really hard. I let it sit for a day and a half and saw it separated with a carmel color glycerine on the bottom. I then drained it out the bottom and proceded to the bubble wash stage. I added a 1/3 water and put the bubble wash stone at the bottom. I let that sit for 4 hours before I shut it off. I let it sit till the next day and i would say close to half of the total mixture was pure creamy frothy white. I drained all the water out the bottom, it ran out just like pure water would, I then got frustrated and dumped it all out because it didn't look right. Where did I go wrong.
Do you think the lye or methanol I used wasn't pure enough??
I am very interested in learning how to do this the right way.I plan to build an appleseed processor.
Another question: I am in Seattle,WA, does anyone know where I can buy methanol and lye (KOH) in bigger quantites. Like 55 gal of methanol???
Thanks
Old 05-01-2006, 08:22 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Thanks
First welcome to FTE Your first stop should be: http://www.biodieselcommunity.org
The answer to your questions.............................
#1. Drain cleaner has aluminum and magnesium, that will KILL the reaction. Use 98 percent KOH or NaOH, Red Devil Lye can be used for small test batches.
#2. 1 ltr oil only requires 200ml of methanol.
#3. All oils require a base amount of 5gms/lye per liter + titration. New [ unused ] oil requires approx 20 percent over the base amount. You should have used 6gms of Lye.
FABMANDELUX.
