Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-21-2006, 06:25 PM
loosecannon39 loosecannon39 is offline
Garage is empty, add now
loosecannon39 is starting off with a positive reputation.
Question flathead swapping/upgrades
hey flatheaders
been away a long time. I asked this once before but didnt receive any feedback.
if memory serves, ford once offered flathead or yblock as options in the same vehicles. later they offered yblock and fe block as options in the same truck.
if this is correct, it seems that an feblock should fit in place of a flathead with the correct parts juggling. any comments???
DAN :
  #2 (permalink)
Old 04-22-2006, 12:20 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
No Dan, the flathead is unique in motor mounts and tranny mounts - nothing else will bolt up. Also they did not offer both flathead and Y-block at the same time in the same model. What you're probably confusing is the fact that the cubes for a flatty are 239 and one of Ford's first Y-blocks was also 239 cid. OR the first Y-blocks appeared in the big trucks (F7 and F8) at the same time the flathead was being used in F1 thru F6's.
  #3 (permalink)
Old 04-22-2006, 01:35 AM
thanks for that info.
DAN
  #4 (permalink)
Old 04-22-2006, 01:38 AM
one more ;
how about y block and fe block interchange???
DAN
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
