4.0L Performance - Ford Truck Enthusiasts Forums
4.0L Performance
Old 04-20-2006, 09:01 PM
Bimmerboy1989 Bimmerboy1989 is offline
Bimmerboy1989 is starting off with a positive reputation.
4.0L Performance
Ok, I have a 1990 4.0L V6 Ranger that needs new heads. I was wondering what kind of things I could do to the engine while I have the heads off. Any input would be greatly appreciated.
Old 04-23-2006, 08:31 AM
RomerB2's Avatar
RomerB2 RomerB2 is offline
RomerB2 is gaining momentum as a positive member of FTE.
New cam? What about porting the heads?
Old 04-23-2006, 11:23 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Delta Cams offers a Rocker Arm Assembly/Pushrod Kit for the 4.0L OHV. Part # F-40 KIT. It doesn't do much for performance but the kit is highly recommended as part of a rebuild.
http://www.deltacam.com/index.php
Old 05-21-2006, 09:16 PM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
Comp Cams Sells A Good Midrang Cam For It, Also Port,and Polish The Heads, Add Larger Injectors, Bigger Tb, And Maf, A Set Of Headers, And You'll Be Rocken!
Old 05-21-2006, 11:48 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Quote:
Indeed, great advice.
Intake and exhaust as well.
RP
Zach
Old 05-22-2006, 02:01 AM
d3adp00l d3adp00l is offline
d3adp00l is starting off with a positive reputation.
I am looking into better ratio rockers, but as far as I can tell these 4.0s ohv have a few things working against them valve sizes, rocker ratios, and compression ratio. Have the machine shop check your clearances(as I have yet to have mine that far apart yet) to see how of the head could be milled to get it around 9.5/10 to 1 compression. Increasing flow and increasing compression means power. The sohc 4.0 is running 9.7 comp and 1.8/1.5 valves which is pobably the largest factors for its 207 hp rating.
Old 05-22-2006, 02:03 AM
Btw I forgot I believe these motors are all using dished pistons, might be able to use flats and get the ratio to the right spot.
Old 06-16-2006, 01:56 PM
jv982 jv982 is offline
jv982 is starting off with a positive reputation.
What intakes are available for the '90 4.0 ranger? I have just installed an e-fan on my truck and have ran into clearance problems that will not be solved with the stock intake.
Old 06-16-2006, 06:17 PM
I did some checking for you, and the oldest I could find was k&n, they have an intake for a 96 4.0, they had a piture, and it looks pretty basic, may have to do a little fabbing, that or get one of those generic kits from ebay. It's hard to find performance stuff for the older rangers. The good news is, Morana v6 racing has developed a 4.5 stroker kit for the ohv 4.0, that should be an awesome product.
Old 06-19-2006, 04:19 AM
I just put together a "cold air" intake for my 92 4.0 using 3" intercooler pipe from ebay I used one 90 degree steel elbow and a 45 degree elbow. I just had to trim the pipes down to fit, no clearance problems at all. the fit on the stock throttle body was a little sloppy fixed by a tight clamp, and I am using a v8 maf body with the v6 sensor on it, with the t/b bored out to 70mm using a v8 butterfly. The aircleaner was just a cone type that clamped to the maf.
Old 06-19-2006, 04:22 AM
I have compiled a list of modifications for the 4.0 and am soon to finish installing them and have it dyno'ed I will be posting the cost and descriptions of them soon, should equal at least 225hp n/a for a reasonable price.
Old 06-19-2006, 04:42 AM
RomerB2's Avatar
That sounds pretty cool, 225 hp's out of a 4.0 is pretty good. I've given my swap a good thought, and I've decided to go ahead and go with a 5.0.
Old 06-19-2006, 06:33 AM
Make sure to check your emisions laws, I couldn't legaly put a 302 in my 04 here in ohio.
Old 06-19-2006, 03:21 PM
RomerB2's Avatar
Ohh I forgot to say, I have a 90 Bronco II.
Old 06-19-2006, 06:09 PM
you should be allright then, the law states here, that the swapped in motor must be of the same year as the vehicle, or newer, they were using the 5.0 up to 01 in the explorer. To be legal, I'd have to swap in the 4.6, thats a big motor as it's a cammer, to much hassle, I'm just gonna build my 4.0 cammer, it has as much hp stock, as the old stock 5.0 mustang, "well", allmost.
2.9l heads 1973dieselhighboy 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 10-04-2015 08:11 PM
4.0 head question 4.go Ranger & B-Series 2 06-26-2008 09:25 AM
4.0L specs 4.0L Ranger & B-Series 23 02-22-2007 10:34 PM
Will 2.9l and 4.0l OHV heads interchange? Titantis 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 4 02-15-2007 09:39 AM
best head gasket for 4.0 bayou sport 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 03-07-2005 01:07 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2004, 40, 40l, arm, cam, delta, ford, hop, kit, manual, ohv, performance, rocker, ups, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
