You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Buy from a bulk distributor in 55 gal drums? Anyone look into this? I mean gas is so high now, and we're going to E-85 as a cheaper alternative. Why not just cut out the oil company entirely and just go buy from an ethanol manufacturer? Should be cheaper cause you won't be paying road taxes and stuff right? Anyone else think about doing this? Why wait to get it at the gas station. Let's just go buy the cheaper alternative direct from the manufaturer and really put the screws to the big oil companies!!!
Well, you'd still have to buy the 15% gasoline to blend in to make it E85. Plus, if the authorities ever got wind of what you were doing, you get busted. They get real, um, unhappy, when you neglect to pay any form of tax.
The upside is you could blend it at any ratio you wanted. You could have E60 if you wanted to. Or you could try E100.
I think there's some sort of "experimental fuel" thing you can get so you can be legal.
It is a good idea though. One that I might just try at some point in the future...
Man, there's got to be a source somewhere. I mean, it's the next coming thing right? It's used as a solvent in manufacturing, as a disinfectant and in labs and colleges. Those places must be able to get smaller quantities from somewhere. Where else could I look?
Actually, the $2.219 price is before any road tax is added. It's the commodity price the wholesalers are trading at. So that extra 54 cents is going to your goverment.
I have made quantities of "absolute alcohol" in the lab. It grabs water like crazy and was very difficult to keep "dry". The fuel grade alcohol can't help but have significant quantities of water in it due to the way it is handled and produced. The reagent or lab grade material purchased from a chemical supply house would have only a trace of water but would have to be kept sealed. The amount of water would probably be called out in the chemical analysis printed on the container.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
I once talked to a local ethanol producer about such a thing, and the pump system they have puts out 300 gallons per minute, and they had no way to slow it down for smaller tanks.
The price right now is high due to MTBE be discontinued, and ethanol taking it's place, so the demand shot up, making the price go high. There are tax breaks in many locations for the ethanol blends as well, which has made it cheaper for a long time. It will be interesting to see if the E85 blends will stay cheap for now, or go high as well, until the supply is more matched to the demand.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
