Rollpan or bumper?
Old 04-19-2006, 08:54 PM
78ford351m's Avatar
78ford351m
78ford351m is offline
Rollpan or bumper?
Anyone have pictures of a f-series with a rollpan. Sounds interesting to see.
Jason
Old 04-19-2006, 11:22 PM
condolan's Avatar
condolan
condolan is offline
I know there's a picture of a rollpan on a mid-70's Ford somewhere in my LMC catalog. I don't think it looks very good though because they have this molding that hangs down in the center for the license plate. Some trucks look better with roll pans than others. In my personal opinon though, roll pans may look nice, but if someone rear-ends you, your whole rear end could be damaged, as opposed to repainting/rebending a steel bumper.
-"$lick"
Old 04-19-2006, 11:39 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
SwOkcOffRoader is offline
The ones without the license plate holder look pretty good IMO, if you have a nice custom tailgate of some sort.....but i can see how they would suck in a rear-end collision....i thought of buying one without the license plate spot, and put the plate onto whatever tailgate i build ..I want to cut a hole in the center of the pan for receiver hitch access, cause im dropping the truck and dont want the hitch to hang too close to the ground.....
Old 04-20-2006, 06:59 AM
77460f150's Avatar
77460f150
77460f150 is offline
I have a rollpan on my 77, I really like it and have got many compliments on it. I don't use my truck for hauling or work so I'm not so concerned about rear end crashes, although it would suck in a rear end collision. I have the one with the plate spot and I don't think it looks too bad. This pan did not come with a plate light and in most if not all states it's the law. I cut a small hole in the pan above the plate spot and mounted a plate light in there so it's completely legal now. here is a pic of the rollpan on my truck, I'll try to post a better pic of it tonight when I get home. -Ed
https://www.ford-trucks.com/user_gal...=41945&width=0
Old 04-20-2006, 09:23 AM
73Custom's Avatar
73Custom
73Custom is offline
There is a good tech article about this, with pics. Under the 'articles' link at top, and 'body/appearance' section on the next page.
I personally prefer the roll pan with the plate in the center. There was a past thread with a pickup that had a solid roll pan and the plate frenched into the tailgate - I didn't care for that. But mine is a work horse, couldn't be without my step bumper.
Marty
Old 04-20-2006, 10:52 AM
77460ford's Avatar
77460ford
77460ford is offline
If you go with a rollpan with a plate you can (in addition to 77460f150 idea) also look at various license plate holders that have the lights built in (if required). I needed a light for mine and the styles and choices were almost endless.
Old 04-20-2006, 01:02 PM
77460f150's Avatar
77460f150
Here is a better pic:
https://www.ford-trucks.com/user_gal...114326&width=0
Old 04-20-2006, 11:28 PM
eedvark's Avatar
eedvark
eedvark is offline
That roll pan looks great.What if you used "nerf bars" of some sort that extended through the rollpan.V-dubs and streetrodders use small "nerf bars " that provide some tow options and jacking mounts but are not big and bilky like a stepbumper.Even a small single tube bumper would provide protection and still look good.
Old 04-21-2006, 03:46 PM
darronb's Avatar
darronb
darronb is offline
I've also got a rollpan on mine, and I love the look
https://www.ford-trucks.com/user_gal...=84347&width=0
might be some more in my gallery.
Old 03-03-2009, 11:47 PM
ziggyzd's Avatar
ziggyzd
ziggyzd is offline
where is the best place to get a rollpan that wont rust out like lmc's typical body parts do?
Old 03-04-2009, 01:28 AM
bmarkline's Avatar
bmarkline
bmarkline is offline
Different roll pan companys make them out of 3 different materials, Steel, Fiberglass, and urethane. I have had all 3 on my chevy trucks, and liked the steel one best- accually welded it solid to the bed sides and blended it all smooth. (But you have to seal up the backside of the welds really good!) you can also just bolt them on- they have the tabs made into them. The Lund brand fiberglass pan was 2nd best, but was destroyed when I got rearended(but steel would have been too), and the urethane type- although flexible, will start to crack after a few years of natures abuse. They also flake the paint off very easy, even with plastic adheasion promoter. If a rock hits the back side of a urethane pan, your losing the paint on the outside. You could try Sir Micheals brand of roll pans, prob better quality than what LMC would have. Look in the back of a truckin, sport truck, or i think another is called Classic Truckin magazine. They always advertize different brands of roll pans in the backs of these mags. Sir Micheals should have the tag light built in- comes with it I think. Also another idea for a tag light, Billet Specialties makes a really trick looking licencse plate frame, with a light built into the top side of it. Comes with all stainless flush mounted hardware, and can even be ordered with a built in 3rd brake light also flush mounted in the top of the frame. Also the whole thing is pollished, then clearcoated, so its maintenence free. Great product I will use again and again.
Old 03-04-2009, 01:43 AM
Don S.'s Avatar
Don S.
Don S. is offline
For those that dont like links.
Old 03-04-2009, 10:33 AM
mwvdub's Avatar
mwvdub
mwvdub is offline
Didn't notice until after I posted that the thread is 3 years old, but here is what mine looks like after 9 years. It was from LMC.
Old 03-04-2009, 10:45 AM
uncle.stosh's Avatar
uncle.stosh
uncle.stosh is offline
Battery disconnect and slicks! Must be a drag truck, huh?
Any more pics of it?
Old 03-04-2009, 10:52 AM
78ford351m's Avatar
78ford351m
hmm. hard to decide. Anyone have any bumper shots?
Quick Reply: Rollpan or bumper?
