My truck acts like its out of gas? - Ford Truck Enthusiasts Forums
Old 04-19-2006, 05:14 PM
ol gray mare ol gray mare is offline
ol gray mare is starting off with a positive reputation.
My 86 f-150 300I6 acts like it is running out of gas to where it will sputter and it will die for a few seconds and then it will fire back up again and it will keep on doing this till u stop. It will only do it after you drive down the road for about 10 miles. I know its not out of gas because i had just filled up. and once the truck cools down it will run fine. i was thinking it was the fuel pump and/or the fuel filter. any help would be great
Old 04-19-2006, 05:51 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
It sounds like your truck is vapor locking.
Make sure the heat riser valve is working properly on the exaust manifold and is not stuck closed.
Also make sure the heat blend door in the air cleaner is not stuck closed, or open to hot air.
Also have the ignition module tested. A bad ignition module can cause simular symtoms when they get hot.
Hope this helps
Old 04-21-2006, 11:39 PM
msfprobass msfprobass is offline
msfprobass is starting off with a positive reputation.
I know this sounds silly....but it is the world of mechanics. My 84 did this too and after I spent alot of money and never fixing the problem I noticed a small hole in the gas tank about 3/4 way up near the top. The hole was smaller than the eraser end of a pencil allowing the fuel pump to loose its prime. Imagine that, I never noticed the problem early becasue as I was repairing the truck to make a daily driver I never filled the tank, only enough to start and rund the engine. I know you said you filled up but check the top of your tank and your lines also. Also like previous: check for vapor lock. Good luck.
Old 04-23-2006, 10:56 AM
Uncle Weezle Uncle Weezle is offline
Uncle Weezle is starting off with a positive reputation.
just had the exact same problem on my 84 f 250 replace the ignition module mine would run perfectly and about 3 or 4 miles down the road would die like it was out of gas , if you tried to restart it would pop through the carb but would not restart. if i let it sit it would start after about an hour it got worse untill it did not start at all
Old 04-23-2006, 06:34 PM
Holmesuser01 Holmesuser01 is offline
Holmesuser01 is starting off with a positive reputation.
If you have fuel injection, you might find that fuel pump pressure is low, indicating that you might have either a bad in-line filter, or, a bad fuel pump. Been there, done that.
Old 04-24-2006, 08:15 PM
mailman37166 mailman37166 is offline
mailman37166 is starting off with a positive reputation.
If you have any rubber fuel lines check them they may be cracked and sucking air
Old 04-24-2006, 10:15 PM
i have talked to a few friends about this problem and they believe that it is the coil. one friend had the same truck as mine and he had the problem and that fixed it
I dont think that i would have a hole in the fuel lines because i park it on a clean cement floor all the time and there has never been a gas leak.
Old 04-25-2006, 09:34 AM
mgraveman mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
that's not it. It may be flooding (too much gas) or too little gas. You will not necessarily have gas on the floor with a hole in the line. You need to check all the things other people mentioned.
A tune up will go a long way - it's probbably past time for a new cap, wires, and plugs. A carburetor adjustment would be good, and setting the timing. From there, you can start trying to find the problem.
Old 04-27-2006, 05:26 PM
I replaced the fuel filter and one section of the fuel line where it was wearing away from the inside out.It doesnt do it very often but it will do it.
It has only died completly once all the other times it just dies for about a second then it is fine again, for about 15 seconds or so then it will die again. It usually only does it when I am tring to keep a constant speed and it started doing it around 45mph but if i would down shift from 4 into 3 and hammer it, it would run fine. But now it does it when im running 60mph. anymore help would be great.
Old 04-28-2006, 02:37 AM
85-300man 85-300man is offline
85-300man is starting off with a positive reputation.
Mine did almost that same thing its carburated. Check and make sure the distributer is on their tight.
Old 04-28-2006, 06:29 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome 85-300man to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 05-01-2006, 12:02 AM
BroncoBill's Avatar
BroncoBill BroncoBill is offline
BroncoBill is starting off with a positive reputation.
Thumbs up Ignition control module
before you waste $$$, spend about $20 and replace it with a new one. Good Luck
Old 05-01-2006, 02:31 AM
Let us all know what is going on, I replaced all of my fuel delivery and ignition before i relized it was a lose distributor when I went to replace it. I felt a little dumb after that but i am not a pro.
Old 05-01-2006, 06:18 PM
the reason why i havent replaced the ignition module, or the coil, or the distributor is because i have been told that it would just completly shut down. which has only happened once and then i thought that it was just out of gas and i didnt want to drain all the gas out of the carb so i just shut it down. after i replaced the fuel line and the filter it has only done it twice within about 2 weeks and that has just been starting out from a stop sign and tring to get up to speed. I can tell when it is going to happen because my truck starts to lose alot of power and it starts to shake (more than it normaly does LOL). im taking it in to a mechanic to have him take a look at it and to check all the inginton module, coil and distributor. but sence the fuel line and filter have been replaced it been running almost fine.
Old 05-01-2006, 09:37 PM
Quote:
You can take the ignition module to a parts store and have it tested. The ignition module can go bad, and the truck will still run.
The most comon problem for Ford ignition modules is that they have a intermitant fault when they get hot. In other words they run and work fine until the module heats up, then intermitent faults develop.
Don't let the old misnomer fool you. Your truck can run on a defective ignition module, but it wont run for much longer, and it will keep getting worse until it quits for good.
Holes in fuel hoses, can cause a "vapor lock like" condition, sucking air etc. A plugged fuel filter will block fuel, and act like it's running out.
Have you check all the things that we asked you to check before, Manifold heat riser, intake heat riser doors, etc..?
It only takes a few minutes, and if they are indeed not working, right, a can of WD-40 or other such penetrating oil most likely will get them working again.
Oh, by the way, do you have the anti stall dashpot attached, plugged in if applicable, and working? keeps vehicle from stalling on hot days.
Hope this helps.
77 with 460 loosing gas, need help jeeperman2001 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-15-2015 11:00 PM
Acts like it was running out of fuel? Royson12 1994.5 - 1997 7.3L Power Stroke Diesel 5 07-23-2014 03:02 PM
2000 Ford Ranger Flex Fuel femalefitter Ranger & B-Series 2 05-12-2014 09:18 AM
1989 f250 Starving for fuel lahammer1 1987 - 1996 F150 & Larger F-Series Trucks 2 05-28-2010 11:43 AM
1991 f-150 acts like it is running out of gas redmom74110 1987 - 1996 F150 & Larger F-Series Trucks 8 02-25-2008 10:14 AM
Tags
2007, 40, 460, 92, act, acting, acts, explorer, f150, ford, gas, im, outta, ranger, runing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
