Econoline Engine ID Help Needed ASAP!!! - Ford Truck Enthusiasts Forums
Old 04-19-2006, 03:13 PM
BuffDaddy BuffDaddy is offline
BuffDaddy is starting off with a positive reputation.
Question Econoline Engine ID Help Needed ASAP!!!
Hi All:
Can anyone tell me a way to determine what engine is in my 1963 Econoline Pickup? I need a new carb kit and need to know what engine I have, IE: 144 or 170.
I cannot so far find any tags or numbers on carb to help in ordering a kit so kinda skunked right now.
Is there a way to tell from VIN what engine is in truck? If so, VIN is: E10SH361192 if that might help.
THANKS in advance for your help. Look forward to your replies ASAP!!!
Buff
Old 04-19-2006, 03:21 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
The s in the vin indicates a 144. although the kit is probley the same.
Old 04-19-2006, 04:46 PM
Talking Thanks!!!
Thank you so much 99F150, your help is appreciated!!!
I was able to pull the carb and found the following under years of grease:
FoMoCo
S M
1.44
Don't have a clue what numbers mean other than bore of carb.
BuffDaddy
Old 04-20-2006, 06:24 PM
Question More Information Found On Carb!!!!
Greetings All:
After removing the carb from the motor, removed years of sludge and grime and on the base of carb found the following letters and numbers: C 30 FA stamped into the base.
Might anyone be able to tell me what carb kit I need from these numbers?? The carb is a FoMoCo Carb.
As always, your help is greatly appreciated :-)
Buff
Old 04-20-2006, 06:41 PM
I think if you take the information on the carb to NAPA they will be able to set you up with the right kit. Those carbs are pretty simple.
Need Help decoding a 1964 Econoline VIN info longm Ranchero & 1961 - 1967 Econoline 11 11-08-2015 08:03 PM
Need Help Decoding Vin # For 1964 Econoline Truck HermansE100 Ranchero & 1961 - 1967 Econoline 9 10-03-2015 01:42 PM
Engine Misfire, PCM failure 2005 Escape bjmbjm1998 Escape & Escape Hybrid 7 07-14-2012 11:15 PM
Econoline Vin Number Ripper454545 1968-2013 Full Size Vans 2 09-30-2009 03:58 PM
Ticking noise form 1999 Ford Expedition NEED HELP ASAP KINGDELL91 Expedition & Navigator 35 05-18-2008 08:44 AM
Tags
1996, 63, econoline, engine, id, parts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
