97 DRW F350 Steel Wheels on 2000 DRW F350?
Nope. No go. Ford in their infinite wisdom decided that they would change the bolt pattern slightly just so you can't change the wheels between OBS and NBS (old body style/new body style).
The 97 has an 8x6.5" bolt pattern while the 00 has a 8x170mm bolt pattern. It works out to a little less than 1/8" difference. Also, the 00 uses a "hub-centric" style method to center the wheels on the hubs while the 97 uses conical lug nuts to center the wheels.
Sorry.
Cody
Sorry.
Cody
1965F100(3onthetree)
2017+ Super Duty
06-04-2016 07:30 PM
