For people with smog, check your vacuum check valves. - Ford Truck Enthusiasts Forums
Old 04-18-2006, 11:33 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Talking For people with smog, check your vacuum check valves.
I have been having problems with my EGR valve for several weeks. Had to replace it cause it was defective. Living in california and their smog rules etc...
Well, the truck started to run like crap again. Thought I had that fixed, but it was just the old EGR going bad I guess.
Anyway did some looking at the system, and there is a vacuum check valve on the line that goes to the EGR valve, from another vacumm source, besides the ported vacuum on the carb. A little tiny thing plugged inside the vacuum line. It was letting vacuum through both ways. It's not supposed to do that. Since the check valve was bad, it was letting too much vacuum to the EGR and causing the truck to run crappy.
The Part is called a Vacuume hose check valve, part # on the valve was a D9AE-AA it was Blue and black. This valve is used from 1979 to 1995.
This valve is also used for distributor, EGR and other vacuum assisted devices.
If you have been having problems with your truck and you can't tell what's wrong or where the problem lies, don't overlook the small things like that vacuum check valve, if you have one.
Thought I'd let you guys know.
Old 05-07-2006, 12:03 PM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
sounds like a plan. Cacuum is one of those things that's easy to forget. I replaced all my hoses (I think) when I bought the truck.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
1997 f250 egr run through cberr 1997 - 2003 F150 21 02-22-2016 08:02 PM
98 Exp EGR solenoid vacuum Thorntontribe Expedition & Navigator 7 11-23-2014 04:30 AM
Vacuum line FAQ f100beatertruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-29-2013 08:41 PM
81 F150 300-6 vacuum questions RVF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-03-2013 07:52 AM
Tags
1998, 2002, check, d9aeaa, distributor, explorer, f150, f250, failed, ford, lines, location, smog, vac, vacuum, valav, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
