88 300 I6.. no start
Old 05-05-2006, 11:35 PM
Icys82GT's Avatar
Icys82GT
Icys82GT is offline
Thumbs down 88 300 I6.. no start
We have an '88 F-150 with a 300 straight 6 in it..
It has been sitting since last summer and this spring here, we tried to start it to no avail...
It'll crank and crank, but no sputter or nothing..
Checked for spark, good.
Turn key on, and you can here to fuel pump prime.
After cranking you can smell gas...
Any help?
Thanks in advance!
Kirby
Old 05-05-2006, 11:52 PM
MrT's Avatar
MrT
MrT is offline
I would check the fuel pressure
Old 05-06-2006, 05:55 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome Kirby to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 05-06-2006, 10:42 AM
Ranger GT2's Avatar
Ranger GT2
Ranger GT2 is offline
How did you check for spark useing the plug or a spark tester? I have had coils that were weak and would spark across the plug but would not fire under pressure. Once checked with a spark tester there was no spark. Have you noticed any corroded connections or bag grounds? You may also want to check your compression to make sure it is good.
Old 05-06-2006, 01:21 PM
Icys82GT's Avatar
Icys82GT
Icys82GT is offline
We just checked for spark with a plug. I'll check for spark with a tester and see where it's at.
Fuel pressure will be next on the list if that doesn't par out.
Thanks for your help and thanks for the warm welcome!!
Kirby
Old 05-07-2006, 02:32 PM
300-6's Avatar
300-6
300-6 is offline
Thumbs up
might want to check all of your electrical wire behind the manfold, and make sure some mice or other creatures chewed throught them, the main plug for the injector harness plugsup directly behind the motor, right above the head.
Good Luck
Old 05-07-2006, 07:19 PM
Icys82GT's Avatar
Icys82GT
Icys82GT is offline
Thanks again!
Next chance I get I will check these things out and let you people know!
Thanks again!
Kirby
Kirbys73F100
Offroad & 4x4
10-09-2012 12:49 PM
Kirbys73F100
08-09-2010 11:06 PM
Kirbys73F100
08-09-2010 02:43 PM
VikingBabe
55
07-05-2007 01:27 AM
fordsuvparts
Kentucky Chapter
01-07-2005 06:40 PM
Quick Reply: 88 300 I6.. no start
